Rocker adjustment
Old Oct 12, 2016 | 08:56 AM
Jeremy Smith's Avatar
Jeremy Smith
Rocker adjustment
I have changed the valve springs but not exactly sure how to adjust the rockers.
I do know to go with the firing order,
1-3-5-7-2-6-5-4-8. I've heard on the firing stroke tighten until push rod doesn't twist then 1-1.5 turns past that. Is this correct?
Old Oct 12, 2016 | 12:34 PM
rowdyredneck's Avatar
rowdyredneck
What engine are you working with? Stock heads and rockers? Ford stopped using adjustable rockers on all V8s back in the late 60s/early 70s so unless you have converted to it to aftermarket studs and rockers all you do is tighten the bolt or nut down and torque it to specifications. I can't remember off the top of my head what the spec is but I usually torque them to 21-24 ft lbs. The only way you can adjust clearance is with different length pushrods or by shimming the rocker pedestals.
If you do have an adjustable valve train, tighten the rocker nut down while twisting the pushrods. Once you reach zero lash, go another 3/4 to 1 turn.
65 ranchero
26
Sep 25, 2018 07:12 AM
Wicked Endings
Feb 20, 2011 08:03 PM
Wawnosh
Oct 4, 2010 04:38 PM
CatFlip
Jul 31, 2006 07:58 AM
MustangGT221
Apr 20, 2002 04:04 PM
