Fender Support Bracket Needed
Old Oct 13, 2016 | 01:03 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Originally Posted by TA455HO
Both of my 66 4WD trucks still have the original rubber strips attached. I don't know of a source for Ford replacements of those, but I did want to say that in all cases that I know of - the rubber strips go on top of the apron, not from the backside.
I just removed the original staples and rubber strips from the one truck and all Ford was doing was cutting up inner tubes for that piece. I can post pics if you want, but on the backside is markings and moldings in the rubber that make it evident that is all it was. The inside smooth surface of the inner tube was faced upward so it looked nice.
I found inner tube material was also used as the lower seal of the transfer case lever.
Old Oct 14, 2016 | 08:00 AM
Highboy4x4's Avatar
Highboy4x4
Bracket
Originally Posted by 1964FORDTUF
I talked to Carpenter. Im going to fab one after all. $15.00 plus 9.99 minimum charge to ship, I have plenty of steel laying around. Thanks all
Did you find one of the brackets yet? I have one if you want it.
Old Oct 14, 2016 | 09:03 AM
1964FORDTUF's Avatar
1964FORDTUF
Sure, please post pics, that would be fantastic!!! I just happen to have inner tubes!
1964FORDTUF
If you can send me one that would be great, I have plenty of other stuff to do on the truck that I can circle back around. You've got my address!! Thanks again!
Old Oct 21, 2016 | 11:48 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Not sure how well this will show up, but the upper one has a curved molded rib just like an inner tube and the lower one has a curved blue stripe. Cut from the side slabs of inner tube, I'm sure.
Old Oct 24, 2016 | 08:27 PM
Highboy4x4's Avatar
Highboy4x4
Bracket
Did the bracket arrive to you safely? I sent it last week and haven't heard back from you yet. Thanks.
Old Oct 25, 2016 | 06:54 PM
1964FORDTUF
Just got home form out of town and there it was!! Thanks, thats super duper!! I love FTE!
3twinridges
Feb 12, 2021 06:22 PM
TexasGuy001
Jul 29, 2015 08:31 PM
Redgranite_Yooper
Mar 26, 2014 09:57 AM
AXracer
Jun 14, 2007 09:50 PM
Walston
Nov 11, 2005 09:50 PM
