Ford F-100 Steering Column Replacement
Old Oct 10, 2016 | 04:19 PM
fish1940's Avatar
fish1940
1970 F-100 truck. Replacing steering column. See attached photo. Column on top is original. Note the steering wheel threaded stud is short. See second photo, the replacement column (model year unknown). Threaded stud is twice as long. Question -- Can I just saw off the first inch of the threaded stud on the replacement column so the steering wheel will fit properly?
Old Oct 10, 2016 | 05:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The replacement 3 M/T column appears to be from a 1973/77 F100/250 because the 1978/79 F100/250 3 M/T shift collar looks completely different.
1973 was the first year that the 4 way flasher switch (you can see its **** poking out of the flange) was made as part of the T/S switch.
3 M/T shift collar is the same: 1961/77 F100/250.
Old Oct 10, 2016 | 05:31 PM
kenny nunez's Avatar
kenny nunez
Steering column
It looks like a later model with the warning flasher switch on the turn signal mount. If both shafts are the same length in relation from the bottom of the column to the rag joint flange just swap the shafts since you also have to swap the turn signal mount.
Old Oct 10, 2016 | 09:15 PM
spdcat72's Avatar
spdcat72
No reason you can't just cut the shaft off. If everything else works, why not? Thread the nut on first to straighten the threads after cutting.
Old Oct 11, 2016 | 04:20 AM
jowilker's Avatar
jowilker
Fish, NO, DO NOT proceed without further checking. In 73 Ford most trucks were switched to the Saginaw power gear and the connect point moved about 2 1/3 in closer to firewall. You are not driving the truck with the column out, try test fitting the new column 1st. When proper fitting has occurred the dash cuff will bolt up. If not the cuff will be under the dash.
The columns are basically the same length from the horn button end of the shaft to the gear shaft that connects to the axle. It is the connect point that is different. |-----x--| vr |----x---|
Column and gear have to be matched. As long a both are swapped either can be used.
John
Old Oct 11, 2016 | 01:15 PM
JEFFFAFA's Avatar
JEFFFAFA
John
Glad to see you pop up here John. Was wondering about you because of that Hurricane.
Old Oct 12, 2016 | 06:43 AM
GaryKip's Avatar
GaryKip
Speaking of hurricane, my parents had 11 inches of water in the yard around the house on Tuesday-close to Sanford N.C.
fish1940
Nov 29, 2016 12:06 PM
SonyResendiz
36
Sep 18, 2014 11:37 AM
Silent Thunder
Mar 29, 2014 07:57 PM
heybear
Aug 12, 2004 05:00 PM
