Paint color matching
Old Oct 10, 2016 | 03:26 AM
The_Drew's Avatar
The_Drew
So I got a canopy for my truck and it is red. My truck is white. Paint code 9m, don't remember the name. It's kind of an off white. I would like to paint my new to me canopy the same color. I know the auto parts stores carry the duplicolor perfect match, I think they are 8 oz aerosol cans. How many would I need to paint a canopy? Is it worth it? Is there a better way? I don't have the money to have a paint shop do it.
Thanks,
Drew
Old Oct 10, 2016 | 10:15 AM
mrollings53's Avatar
mrollings53
The can says how many square feet it covers. You can estimate how much you need by thinking of the canopy as 5 rectangles, and add their areas up. Going from red to white is going to need a lot of coats. I'd suggest 2 coats of primer and at least 2 coats of white. Don't forget to scuff the surface up and clean it well before painting. Also use a gray primer.
Old Oct 10, 2016 | 10:48 AM
The_Drew's Avatar
The_Drew
Thanks I didn't think about the square footage being on the can haha
Old Oct 10, 2016 | 06:58 PM
Diesel_Brad's Avatar
Diesel_Brad
If the cap is single stage(not clear coat) you will want to use primer sealer FIRST or the red will just bleed thru the white.
Do yourself a favor and buy a Harbor freight $20 HVLP gun and a quart of primer sealer and a quart of the white.
it will cheaper in the long run, it will turn out 10x better and you will have a spray gun for your next project
Old Oct 10, 2016 | 11:29 PM
raystankewitz's Avatar
raystankewitz
Originally Posted by Diesel_Brad
If the cap is single stage(not clear coat) you will want to use primer sealer FIRST or the red will just lead thru the white.
+1 on this. Something as big as a cap is just too much to rattlecan properly. You can get the paint and sealer at an automotive paint shop.
Old Oct 11, 2016 | 06:35 AM
The_Drew's Avatar
The_Drew
The cap does have clear coat on it that is peeling off. Are there any extra steps that have to be made?
Just thinking about bedlining the thing now. I think it will hide all the imperfections a little better, and easier touch up.
Old Oct 11, 2016 | 09:11 AM
mrollings53
You should sand it smooth no matter what you put on it. Peeling paint will continue to peel even under bed liner. Eventually your bed liner, or whatever topcoat you use will peel off in big sheets.
If you do get the spray gun get a good air filter setup that removes water and oil. You can go cheap on the gun, but quality counts with the filter.
Old Oct 11, 2016 | 03:56 PM
Diesel_Brad
Yes, any loose clear needs to come off(should sand all off)
Then prime, and paint.
PLEASE, do NOT bed line it. It looks like crap, collects dirt, and would make it IMPOSSIBLE to ever paint it
aussiecowboy
50
Oct 27, 2013 08:58 AM
Gorgoth
Paint & Bodywork
Jul 19, 2009 11:58 PM
sturoe
Paint & Bodywork
May 29, 2007 08:46 PM
fordff
Paint & Bodywork
Mar 21, 2006 01:26 PM
ford81
Paint & Bodywork
Mar 4, 2006 07:02 PM
