Another Exhaust Question
Old Oct 7, 2016 | 06:38 PM
corvair62's Avatar
corvair62
Well folks, my headers are full of holes, the pipes have rusted off and the mufflers have just about quit muffling. The question I have is on my headers. The engine in this truck was swapped out before I got it. It is a 351w with a c4 automatic 2wd. Any body got a good suggestion for replacements.
Old Oct 7, 2016 | 07:50 PM
HIO Silver's Avatar
HIO Silver
According to fellow FTEers with a 351 Windsor - https://www.summitracing.com/parts/bbk-1515
Old Oct 7, 2016 | 08:51 PM
corvair62's Avatar
corvair62
Thanks HIO Silver
Old Oct 8, 2016 | 11:27 PM
boingk's Avatar
boingk
If you are doing the whole thing I would recommend long-tube headers. Not only will you get a lot more topend out of the engine, your midrange will improve and you will generally get better economy due to superior exhaust-pulse scavenging of the cylinders.
As they exit under the floor of the cab you will also have a lot easier time fabbing the rest of the exhaust - it will be a straight pipe with a muffler and then whatever you want for the exit.
I would only go the 'shorty' type headers if fitting to a stock vehicle with pre-existing exhaust system was a concern.
Also, if these Hedman headers will fit into a Ford Maverick or Mustang then I see no reason why they wouldn't work in an F-truck:
https://www.summitracing.com/int/par...8300/overview/
Cheers - boingk
the5schlueters
64
Jun 7, 2013 10:19 PM
wyo_driver4
Exhaust Systems
Jul 7, 2007 04:05 PM
masseysbronco
1978 - 1996 Big Bronco
Sep 14, 2006 06:53 PM
Meathead
Aug 1, 2005 04:33 PM
mtm1972
Oct 11, 2003 04:37 PM
