Sponsored by: Real Truck
Problems when starting
Old Oct 7, 2016 | 12:26 PM
tws3b2's Avatar
tws3b2
2003 f250 5.4 86000 miles. When I start the truck, "especially after it sits a day or more" it starts to fast "Rushes". Like the gas pedal is all the way to the floor. I have taken it to the Ford dealer and they say they can find nothing wrong. They say all fords start up fast but I know this cannot be right. If I start it and let it run awhile then start it again it starts much slower. It only rushes like that a second or two and slows down. Today I noticed that when it started all the gauges pegged out. The speed indicator went up past 100mph sitting still in park. Then they all dropped down to zero then back to where they should be. Ideas???
Old Oct 7, 2016 | 12:38 PM
projectSHO89's Avatar
projectSHO89
Well, first off, you probably need a new battery.
Old Oct 7, 2016 | 12:58 PM
Wingit929's Avatar
Wingit929
So when you start it the revs go high? does hitting the throttle let it go back down?
My thought is one of the sensors is bad letting the computer think it is cold causing the high RPM.
Old Oct 7, 2016 | 02:13 PM
tws3b2's Avatar
tws3b2
Real high. It only goes high for a second or two and then down on its own. I do not have to touch the throttle before or after starting although I have tried hitting the throttle before just to see if it helps, does not. It only does it after sitting a day or more. It will start, rush and drop before the rpm needle can catch up, if you know what I mean. After first starting its fine, normal until its sits a day or more.
Thanks
AKHunter93
48
May 29, 2017 08:45 AM
Bigfoot46555
Sep 27, 2011 09:16 AM
Spamy
Modular V10 (6.8l)
Dec 5, 2010 04:02 AM
BigRy
Nov 9, 2009 11:15 AM
f150-az
1997 - 2003 F150
Jun 2, 2003 09:20 AM
