WHISTLE SOUNDS
Old Jan 3, 2002 | 06:40 PM
witt3696's Avatar
witt3696
WHISTLE SOUNDS
I've got a 94 F-150 w/ 302 V8. Everytime I start it I let the engine run for awhile and let the idle come down. While doing that I've noticed that there is a very loud whistling sound coming from under the hood. I know it's coming from the motor somewhere but I can't tell where. Does anybody know what could cause this. And the other thing is yesterday the driver's side vent wouldn't blow any air, but now it does...any ideas??
Old Jan 3, 2002 | 10:42 PM
PAUL_2's Avatar
PAUL_2
WHISTLE SOUNDS
Check all the vacuum hoses . The Heating & A/C system uses a series of vacuum hoses to control which vents air comes from .
Old Jan 5, 2002 | 01:44 AM
fordmanboss302's Avatar
fordmanboss302
WHISTLE SOUNDS
yah mater a fact i had that same problem today while doing some fuel injection work, its the PCV valve on the passangers side, when its not in place it whistles because it is sucking in air from the outside insted of from the valve cover, the PCV valve comes out of the valve cover and then goes into air intake on the back side, it is crucial the the emissions equipment. it keeps a constant vacuem in the block, and closes when it sences back presure, the vacuem is also esencial he the proper opperation of the engine
even though its a truck, it still deserves a little lovin'
Old Jan 5, 2002 | 11:12 AM
Phillip Guidry's Avatar
Phillip Guidry
WHISTLE SOUNDS
Leydon101
May 7, 2013 05:55 AM
davisonfamily
1983 - 2012 Ranger & B-Series
16
Mar 30, 2013 03:04 PM
H1449-6
Aug 16, 2011 07:40 PM
81-F-150-Explorer
Jun 10, 2009 09:10 PM
BLK94F150
1997 - 2003 F150
May 10, 2009 09:03 AM
