2005, F350, 6.0, Fan clutch
Old 10-06-2016, 04:54 PM
Weltonsam's Avatar
Weltonsam
Weltonsam is offline
I had the EGR, delete done on my truck. Fan has always made noise, checked all pulleys they're ok. Definitely sound from Fan. Fan spins freely when truck is off. Im thinking new Fan clutch assembly is in needed. Is Motorcraft the only one that's good to use for a replacement. I don't want any refurbished parts. Also what about the sensor. Does that go along with the unit. Can anyone help.
Old 10-06-2016, 07:05 PM
jmaskew's Avatar
jmaskew
jmaskew is offline
Yes motorcraft for sure. Check ebay you might find a good deal. Definitely stay away from Dorman fan clutches... I found out the hard way.. lol.
Old 10-06-2016, 07:28 PM
Weltonsam's Avatar
Weltonsam
2005,f350 6.0 super duty, fanclutch
Ok. Now that you say use Motorcraft, there is a heavy duty version for plowing. I have horses and tow. What's the best fanclutch out there, would you still go with Motorcraft?Another question. I had the EGR delete done and need to install a chip to get rid of the check engine light. What are some recommendations. Need it for towing and maybe a little more power. Thanks
Old 10-06-2016, 07:34 PM
Weltonsam's Avatar
Weltonsam
Ok. Now that you say use Motorcraft, there is a heavy duty version for plowing. I gave horses and tow. What's the best fanclutch out there, would you still go with Motorcraft?
Old 10-06-2016, 08:17 PM
mattdoc88's Avatar
mattdoc88
mattdoc88 is offline
The plowing clutch won't help towing at all. It just has a higher fan speed when at the slowest setting, to make up for the reduced airflow with a plow in front of your grille combined with the slow speeds of plowing parking lots. I wouldn't get the plow clutch unless you plow.
Hayden fan clutches are the same as Motorcraft, but without the label. When I got one a year ago, rockauto had the best price delivered.
Old 10-06-2016, 11:31 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Check with FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
They can get you a Ford part as a fair price and it a real Ford part with the warrantee.
Also the clutch assembly will have the speed sensor in it.
It a fluid type clutch and should have some resistance when you try to turn by hand.
But it should not free spin on you.
Sean <BR>
6.0L Tech Folder
Pest007's Avatar
Pest007
Pest007 is offline
I have the same issue, right after you turn off engine, you can hear what sounds like a bearing with sand in it rolling around until the fan blade stops. Fan works 90% of time, the only time I knew it needed attention was when towing my trailer up steep arizona hills and when it engages at 100%, it was making some squealing noise, and not the belt kind... other than that it works for just normal driving with no issues...
I'm curious about the difference between the Hayden and Motorcraft, especially since its about a $100 difference!
Old 10-07-2016, 12:03 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Are you sure that is not the turbo spooling down?
Sean <BR>
6.0L Tech Folder
Old 10-07-2016, 02:26 PM
FiveOJester's Avatar
FiveOJester
FiveOJester is offline
Wasn't there an issue with certain years where you unplug the EGR valve and the fan doesn't control right? I think it was a problem of the fan NOT engaging, which wouldn't explain your issue.
Old 10-07-2016, 07:11 PM
mattdoc88's Avatar
mattdoc88
I replaced my Motorcraft that was on its way out with the Hayden 3261. As far as I could tell on the bench and from how it's been working, they were the same part but with Motorcraft printed on one. The p/n info was all printed in the same type of font with the same type of printer on both clutches.
See my thread, especially the post I'm linking directly to, for pics:
https://www.ford-trucks.com/forums/1...l#post15317955
Look at the circle just inside all the fins - you'll see a word like "VISTRONIC" and some part numbers 180° away from that that look identical.
Scroll up one post from the one I linked directly for a minute and a half video I took showing how similar the two are.
Old 10-10-2016, 10:44 AM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
Hayden is the OEM manufacturer, and one of, if not the biggest name in fan clutches in the world.
Old 10-10-2016, 12:01 PM
wedge542's Avatar
wedge542
wedge542 is offline
When you buy local look inside the box before you pay,see if any wet looking areas inside box,means clutch was not laid right and lost some slcn oil content, it does not hold alot so a small amount lost may cause not to work right or lockup full, yep new can do it too,think it falls under qlty cntrol issues.
Old 10-10-2016, 05:49 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
That was a problem with the old ones too. I replaced a fan clutch on my
1988 Ranger and the box had a big sticker with lay and store this way arrows on it.
Sean <BR>
6.0L Tech Folder
amsk8er1983
07-25-2016 05:48 PM
egregg57
05-27-2013 05:44 PM
wileec
06-14-2007 09:31 AM
eclectro
06-15-2006 10:51 PM
rsrxc700
08-06-2003 09:21 PM
Quick Reply: 2005, F350, 6.0, Fan clutch
