They do not fit in regular tunnel-type washes. only a couple of inches clearance past the folded mirrors. That big fat back just won't fit. And for the lift and levelers, you have to be careful. Height clearance is 84 or 86 inches usually.
The install brackets are made by gator and only use one screw which is already part of the body. The rest is snap fittings. Exact same as f150.
I did some digging and emailed gatorback who said they are making them in Canada and delivering to dealerships oct 31st.
Just so I understand.... The F350 flaps as well as others will be hitting the Dealerships at the end of October? Kool. My Sales Rep was on vacation and Didn't want to bother him over the issue.
I called Duraflap, they expect to have their drill-less full size mud flaps ready for shipping in the next couple weeks.
On the AL F150 they use Aluminum washers and parts to keep unlike metals from touching the truck. I assume they will do the same.
Ya i heard the same thing. The full kits, No body drill bracket system and heavy duty mud flap should be available on the 31st. In fact i came across the install videos on their website. Sweet set up! I've heard that a heavy duty no body drill flap system from Gatorback using their GB2124 is coming to Ford for the new dually as well.
Heard the same, available at ford dealers the 31st. The install video for these are on their website now. Sweet set up, No body drill bracket system with a heavy duty mud flap. I have also heard that a heavy duty no body drill set up for the Dually is coming soon using their GB2124.
