fuel tank problem
Old Jan 13, 2006 | 04:39 PM
gkl273's Avatar
gkl273
fuel tank problem
Hello! This is my 1st time on this site. I need some information and help. I have a 1988 F150 with a 5L engine. I have just replaced both fuel tanks and installed new pumps in each tank. When I use the front tank I have no problems but when I switch to the rear tank my front tank fills with gas and pours out the filler tube. Thanks
Old Jan 13, 2006 | 05:22 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Jan 13, 2006 | 05:30 PM
'88_F-150's Avatar
'88_F-150
Well I have heard of this problem there is a defect in a check valve in the tank switching system which allows fuel to be pumped from one tank to the other but I dont know any of the specifics Im sure one of the other people in the forum will be able to help you more good luck
Old Jan 13, 2006 | 05:43 PM
subford's Avatar
subford
You have a bad Fuel Selector Valve on the Frame Rail. This is a non-electric valve and depends on the fuel pressure of the selected tank pump to switch the valve. The check valves on this system are in the Fuel Selector Valve on the Frame Rail. You may have a bad or wrong pump in the selected tank but more than likely it is the valve.
Here is a diagram of the valve but I understand that the new replacements do not have a filter in them now.
Old Jan 14, 2006 | 07:26 AM
gkl273's Avatar
gkl273
Fuel tank problem
I just want to say thanks. I did see this valve in the chiltons book but there was no information about it. Thanks again.
Old Jan 14, 2006 | 07:50 AM
subford's Avatar
subford
I never buy one of them off brand manuals as they only copy what they want to out of the Ford shop manuals. The first thing I do when I buy an another Ford is buy a set of Shop Manuals, Shop Prints, CD, and the Electrical and Vacuum Troubleshooting Manual. I still have all of the sets of manuals that I ever bought for them plus I still have eleven Fords and they date from 1956 to 1995. I must admit that when the prices got a little high a Helm I started buying from eBay.
Old Jan 15, 2006 | 10:03 PM
JimCT's Avatar
JimCT
I have an F-250 of the same year & dual tanked. If I recall, it's all electric in the switching. I have the same problem except that I know about this problem and I usually don't run the rear tank unless I know my front tank has some room. Anyway, back to the point, I think I recall reading in me Haynes' manual that the routing of the fuel lines causes some of the rear tank's fuel to return to the front tank. But this is mere fuzzy speculation.
The '88's have low pressure electric fuel pumps in each tank so it's just a matter of switching which one is on. I replaced both my tanks at the same time and replaced the pumps as well, I'm certain of this one. I don't know any fix (It's low on my list of priorities), but I just wanted to make you aware that this other direction of thought.
best regards! -Jim
Old Jan 16, 2006 | 07:24 AM
subford's Avatar
subford
best regards! -Jim
I have a 1988 150 and no it is not electric in switching. I think 1985 was the last year that Ford used electric tank switching on FI 150s. Can not say on larger engine (460 carb) Trucks.
Yes the 1988 do have two in-tank pumps (one in each) and one on the Frame Rail.
Newer Trucks (1991? on) do not use the Mechanical Valve and went to check valves in the Tanks.
So from what I can gather:
19?? – 19?? = Hand Valve
19?? - 1985 = Electric switching
1986 - 1990 = Mechanical switching
1991 - To date = Check Valves in Tanks.
If any body knows for sure that any of the dates are wrong or can fill in any dates please do so.
