Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
pull engine out the top or drop subframe ?
Old Oct 5, 2016 | 09:00 AM
gearhead5's Avatar
gearhead5
Ok so I Don't have much experience with front wheel drive, I'm a heavy equipment/truck mechanic, I'm pulling a motor out of an 03 Taurus to put in an 01 escape awd. Should I pull the motor out the top or unbolt the subframe and drop everything out the bottom? Other tips would be appreciated as well, thanks
Old Oct 5, 2016 | 08:33 PM
projectSHO89's Avatar
projectSHO89
Drop it. That way, you can keep the transaxle and engine together and then separate them where it's easy to get to the bolts.
Old Oct 6, 2016 | 08:15 AM
tomw's Avatar
tomw
I would have said it depends on what you have available to do the job. If you drop the subframe, you have to raise the vehicle high enough to drag the engine/trans out from under. If you have a cherry picker, and no method to support the Taurus up high, I'd pull it out the top, taking both engine and transaxle at once.
tom
Jalopy48
Large Truck
Jul 29, 2010 04:08 PM
Fallguy2004
Jul 8, 2010 06:48 PM
rb76543
Jul 7, 2009 11:16 PM
94E1504.9L
Mar 26, 2009 02:51 PM
wakojoe
Jan 23, 2006 11:41 PM
