302 won't stop pinging
Old Oct 10, 2016 | 07:25 PM
  #31
stak's Avatar
stak
Originally Posted by BeholdenZippy
I do have a spare that came with a bunch of other parts that I bought. I tried using it some time ago and it didn't make a difference. Ford parts says they no longer make the sensor. If cleaning mine doesn't make a difference, would a Delphi be a good alternative?
i don't think you will have a problem with Delphi part. i would just keep my eye open the next time you hit your local salvage.
Old Oct 10, 2016 | 07:48 PM
  #32
BeholdenZippy's Avatar
BeholdenZippy
Will do. My regular yard has around 3 of these trucks with 302s. Seems like most stuff still works but everything is all rusted out from all the salt on the roads.
Old Oct 10, 2016 | 07:55 PM
  #33
stak's Avatar
stak
yes tell me about it. i am in NE Ohio and the salt eats everything
Old Oct 12, 2016 | 01:40 PM
  #34
BeholdenZippy
Still pings with new MAF sensor. Any idea what would cause it to not ping with it unplugged other than the MAF sensor?
Old Oct 12, 2016 | 02:20 PM
  #35
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Even with a new sensor on, your MAF harness to/from the computer may have some issues.
Old Oct 12, 2016 | 03:10 PM
  #36
rla2005's Avatar
rla2005
No feedback signal from the MAF causes the computer to run in open loop/default mode. This usually pulls timing and enriches the fuel/air mixture. Both will significantly lessen the chance of pinging.
Old Oct 12, 2016 | 04:02 PM
  #37
BeholdenZippy
Do you have a wiring diagram so I can ohm check the wiring between the sensor and the computer?
Old Oct 12, 2016 | 04:06 PM
  #38
BeholdenZippy
I was wondering about that and if it doing that might be covering up another issue that I have somewhere else.
Old Oct 12, 2016 | 05:16 PM
  #39
GoinBoarding's Avatar
GoinBoarding
Unplugging the MAF sensor should put the PCM in open loop. Sounds to me like something related to closed loop operation/feedback. It would be interesting to know what the oxygen sensors are reading when the truck goes so lean. Does this truck have 1 or 2 oxygen sensors?
Edit: RLA2005 already said this.
If possible, monitoring ignition advance, oxygen sensor readings, throttle position, coolant temp, and intake air temp under various conditions (i.e. engine load) would be helpful. I'm not too familiar with OBD-I scanner capabilities but its a simple thing to graph with OBD-II scanners.
Old Oct 12, 2016 | 05:58 PM
  #40
BeholdenZippy
It only has 1 oxygen sensor. It is after the exhaust leak that I have so reading may not be totally accurate. Unfortunately I don't have a scan tool. It would make it much easier to be diagnosing everything.
Old Oct 17, 2016 | 07:22 PM
  #41
BeholdenZippy
Due to me not having the knowledge/time to be diagnosing this issue, I brought the truck to a local shop. Apparently there is a tsb for the spark plug wire routing that they will be trying. They said that if this doesn't fix the issue they think its a cylinder running too hot due to a plugged water jacket(coolant was brown sludge when I bought the truck 2 years ago). They also said the passenger side manifold is cracked right by the exhaust port that has the cylinder that has the pinging. The exhaust temperature in this spot is about 100 degrees hotter than the rest of the manifolds. Is it possible that the exhaust leak or a plugged water jacket be causing my problem?
Old Oct 17, 2016 | 07:24 PM
  #42
BeholdenZippy
They also flow checked the fuel injectors(they were good). Compression was around 140 psi in all cylinders and they used a camera to look in the cylinders and the pistons(did have a small ring of carbon on the edge of the piston) and cylinder walls were clean and still had factory machining marks and cross hatches were still visible on the cylinder walls.
Old Oct 19, 2016 | 03:01 PM
  #43
BeholdenZippy
I got a call back from the shop and they said the pinging is gone. They flushed the cooling system with CLR and got a bunch of rusty sludge coming out of the engine. This was causing the combustion chamber to run too hot and ping.
Old Oct 20, 2016 | 12:36 PM
  #44
BeholdenZippy
I got my truck back from the shop and got to drive it myself. The pinging is completely gone. Thanks everyone for all your help. It was good to be able to knock some stuff off the list of possibilities before I brought it to the shop.
Old Oct 20, 2016 | 01:28 PM
  #45
joey2fords's Avatar
joey2fords
sounds like you found a good shop that actually does some diagnosis. hang onto those guys !
