mirror defrost
Old Oct 3, 2016 | 12:05 PM
highoctane74's Avatar
highoctane74
mirror defrost
Has anyone successfully converted their mirrors to defrost?
I am wanting to give it a try, have trouble figuring out what to use.
Old Oct 3, 2016 | 08:31 PM
Dave145's Avatar
Dave145
Depending in your style of mirror, I know Velvac makes a kit (mirrors and all) for heavy duty trucks. If you've ever seen a Snap On truck with the big chrome mirrors on it those are the ones I know of. I think they make other kits too but I may be wrong.
Old Oct 3, 2016 | 08:51 PM
highoctane74
Ok thanks. I remember seeing a kit. It made it so you could attach the wires to the back of the mirror. I can't figure out where it was. Already scraping frost off the windows here, time for an intervention!
Old Oct 3, 2016 | 09:46 PM
Dave145's Avatar
Dave145
Yeah I'm not looking forward to the frost here either especially since I have the huge towing tripod mirrors! But yeah I know the kit includes the mirrors with elements in them and instructions. The kit I KNOW exists that we install on the snap on trucks has the giant 10"x5" mirrors. Way too big for our rigs but they may make something for us.
Side thought....those huge mirrors may look kinda cool on our rigs with some custom brackets....
Old Oct 4, 2016 | 09:35 PM
lasermike's Avatar
lasermike
If you can get the glass out in one piece, you could cobble together something using a mirror heater from ebay. Problem is, it won't be the right shape so it will look kinda crazy as it melts the ice but I would think that unless you were deep into the snow belt, it should get most if not all of the mirror clean.
ebay also has heated west coast mirrors but they are too big even for the type 3 frames without making new brackets. It does look like I could get the glass out of the type 3's and retrofit heaters in.
Old Oct 4, 2016 | 09:39 PM
Dave145's Avatar
Dave145
Actually, could you use parts from a kit for a rear window defogger? Not sure exactly how those kits work, but maybe you could use parts of the grid for the defogger in each mirror?
Old Oct 4, 2016 | 09:59 PM
lasermike's Avatar
lasermike
Maybe.
The grid is made up of adhesive backed resistive material. It's designed to consume a certain amount of current. Too much and it'll burn out or blow the fuse. Too little and it won't be effective. You could use a constant current source to drive a partial grid and slowly increase the current until you get the defrosting level you want. There's more info here than even I knew
You don't want the grid on the outside of the glass, it'll look real tacky and won't last long so you'll still need to get the glass out of the housing. I used to wonder if you could just shove a bunch of resistors into the housing and raise the entire thing above ambient but I don't think it'd work all that well when it's icy.
Edit:
Second thoughts about putting the grid on the back side of the mirror. The mirror is a "second surface" type meaning the reflective material is on the backside of the mirror. I don't kow how sturdy that material is, it might fail or degrade due to the chemicals in the grids adhesive.
vicvet
May 26, 2014 08:06 PM
ALAN_50501
2004 - 2008 F150
May 5, 2013 02:19 PM
SHOpar
Oct 8, 2007 08:42 AM
texex
All Things Towing
Feb 27, 2007 05:19 PM
TimTheGuitarMan
Jun 21, 2006 03:44 AM
