Plugging Return lines on a 7.3IDI????
Old Oct 2, 2016 | 11:09 PM
CrispyWafer's Avatar
CrispyWafer
Ive heard of people doing... How do i do it? And why would I?
My fuel system is new, and doesn't give me any issues.
Old Oct 3, 2016 | 02:39 PM
tjc transport's Avatar
tjc transport
i ain't rite
you can not plug the return lines, the unused fuel needs a way to get back to the tank.
Old Oct 3, 2016 | 07:42 PM
Macrobb's Avatar
Macrobb
The only thing you /can/ plug, if needed, is the return line from the fuel filter.
The fuel filter doesn't /need/ a return line; it's there to remove air before it gets to the IP and help with bleeding. it also has a check valve inside the fitting which prevents air from entering the fuel filter(going backwards).
Unfortunately, after 25 years, usually that check valve is broken, which can cause some 'drain back' issues(hard start after sitting, fires right up, dies and then takes a lot of cranking to start), especially if you have leaky injector return O-rings.
The injectors and IP require their return lines; attempts to plug either will result in a non-working vehicle.
Ineedhelpfastsoicang
Apr 14, 2016 09:01 PM
TRIKSTR
Sep 25, 2013 09:33 PM
mrblonde108
Aug 30, 2009 03:55 PM
2New2Fords
Sep 29, 2006 05:54 PM
tkcollin
Oct 31, 2003 10:29 PM
