Sponsored by: Auxito
transfer case noise
Old Oct 2, 2016 | 06:59 PM
jake22si's Avatar
jake22si
transfer case noise
I've got sort of a howl going on, was thinking rear end, but when i jacked up the wheels and spun the driveshaft the noise seemed to come from the transfer case area. I haven't had a chance to check the fluid yet, could it be a bearing in the t-case? Its only when i'm on the gas if i let off its gone. 2001 f150 super crew 4x4
Old Oct 3, 2016 | 04:06 AM
thzpcs's Avatar
thzpcs
It's very possible. I'd definitely check that fluid first.
Old Oct 4, 2016 | 06:00 PM
jake22si's Avatar
jake22si
I got under and opened the fill plug on the transfer case, tranny fluid came oozing out, didnt smell burnt or bad at all. And I think it was the fill plug, it was above the cross member, the drain i take it is the one closer to the bottom
Old Oct 10, 2016 | 03:58 PM
jake22si's Avatar
jake22si
Im going to try backing off the rear e brake
Old Nov 22, 2016 | 03:20 PM
jake22si's Avatar
jake22si
So, I had someone swap out the outer bearings in the rear end because of the howling, only did it after warmed up, and seemed do it more turning a certain way but no play in the wheels. Still howled a little after bearing replacement so I replaced the calipers and that did the trick. I told them to check the brakes but apparently didnt
bowkill
2004 - 2008 F150
Jun 23, 2013 11:35 AM
SuperDuty93
Apr 10, 2012 03:33 PM
fdwjr
May 26, 2009 12:11 PM
holocbr
Feb 2, 2006 10:01 AM
otpracer100
Aug 20, 2005 12:11 AM
