Minnesota Chapter Join Chapter, Leader: fordpower88
October BS Thread
Old Nov 1, 2016 | 09:39 AM
  #571
651_F350_KR's Avatar
651_F350_KR
Originally Posted by fordpower88
There aren't going to be too many modifications you can see by looking at it other then what you already said. The other updates would be internal ones you couldn't see by looking at it. I am guessing you have a 4 inch exhaust system being it is aftermarket but grabbing a tape measure and checking will tell you in short order what is on there. Where is the pyro located in the downpipe or exhaust manifold? Manifold is where it should be. What type of tuner or programmer is it? Do you have gauges or a monitor? Is there a coolant filter on it? That would be mounted next to the radiator on the pass side.
BTW you want to make sure you run OE oil and fuel filters on it.
Also just as an FYI there is a new bs thread started every month so there won't be much posting in this one if you are wondering.
That's kind of what I was thinking, I will have to do some investigation then and see where the wire for the pyro is going. As far as tuner there isn't one installed now, but when I talked to the previous owner he said he had it chipped. And I've been having Boyer do the multi-point/oil changes so I should have OE filters. I will move this over there and see if there's anyone around the cities that would want to meet up. How far west are you? I may be in Clinton/Graceville area this weekend.
Old Nov 1, 2016 | 10:04 AM
  #572
fordpower88's Avatar
fordpower88
Well then you will be going right by me. I live just outside of Morris. Depending on when you are going through we could easily meet up.
HP junkie
Minnesota Chapter
214
Nov 30, 2018 07:16 PM
fordpower88
Minnesota Chapter
251
Oct 2, 2018 01:57 PM
Nice Work Truck
Connecticut Chapter
295
Dec 1, 2014 07:48 AM
fire240
Idaho Chapter
91
Sep 30, 2011 03:38 PM
67nukeford
Nebraska Chapter
902
Oct 31, 2010 07:43 PM
