Sponsored by: Auxito
Sway Bar Diameter?
Old Oct 1, 2016 | 12:01 AM
Lime1GT's Avatar
Lime1GT
Question Sway Bar Diameter?
Where do you read measurement for front sway bar diameter when buying new bushings? My 2002 F150 4x4 S/Cab XLT bar diameter gives me 25.??mm roughly; Slightly over 1". Moog seems to only sell sway bar bushings starting at 27mm. Is that what I use or am I not supposed to measure the bar diameter? I see Energy Suspension sells 25mm bar bushings but I don't want that style for winter use.
Old Oct 1, 2016 | 05:58 AM
enriched&beyound's Avatar
enriched&beyound
I just measured the sway bar on my truck when I replaced mine (We have nearly identical one). I remember the new ones were pretty snug and I use lithium grease to help slide them in place. I went and just re-measured mine it is the same 25mm
Moog does offer a 25mm...it just doesn't come up for our truck...not sure why?
What are you seeing in difference that gives cause for concern for winter??
Old Oct 1, 2016 | 11:01 AM
Lime1GT's Avatar
Lime1GT
I had installed poly bushed rear lower control arms in my 05 mustang and they were great. I like to drive that car a couple of times in the winter during storage but not unless it's extremely cold so no salt gets to it. I took it out for a ride in -30 temp and on every bump it sounded like the rear suspension was tearing apart. I guess the supplied grease didn't like the cold temps.
Old Oct 1, 2016 | 12:56 PM
enriched&beyound
I guess when its that cold, things just ride like a lumber wagon....I just don't expect that the ride is going to be very smooth and wouldn't necessarily contribute it to just the a poly bushing. I understand what your saying though
Old Oct 2, 2016 | 12:28 PM
Lime1GT's Avatar
Lime1GT
Oh no, the ride with the stock control arms is fine at cold temps as the rubber bushings still twist/flex. Even the poly didn't ride that bad. I think the poly bushings are hard as a rock at that temp so it's the bushing trying to turn in the sleeve that makes the exaggerated rubbing noise. Thanks for your interest.
Old Oct 3, 2016 | 04:07 AM
thzpcs's Avatar
thzpcs
I've had poly bushings forever and haven't really noticed a significant difference in ride quality when cold. Can be a bit squeakier though.
Old Oct 5, 2016 | 12:01 AM
Lime1GT's Avatar
Lime1GT
OK, so I used a couple of wrench's to measure the sway bar instead of a caliper. 1" doesn't fit, 1 1/16" fits, so I guess I order the 27MM bushings for a 1.06" bar. Problem solved, thanks for your help.
DidieX
May 2, 2016 07:23 AM
johnnem
Apr 14, 2010 07:14 PM
notyettoday
Mar 16, 2009 04:10 PM
Alpine6
Oct 22, 2007 07:40 PM
mweeps
1978 - 1996 Big Bronco
Aug 6, 2004 03:35 PM
