I'll never see one, we get Hercules flying here every so often and they land at the Red Lake airport, usually have guys parachuting from them doing maneuvers..
To accommodate for a shorter runway the planes took off at night, using the heat rising from the runway as lift.
Please don't be upset Rick if i make a slight correction here.
Its not the heat rising from the runway.
The colder air of night itself just gives much greater performance to fixed and to rotary wing aircraft.
On a cold day a plane takes off in less distance and climbs better at any given weight crom gross down.
Helicopters can lift more, liftbit faster, and hover at greater altitudes in cooler air.
Thanks Ian. I just repeated what was said in the newspaper.
