Tailgate lock?
Old Sep 29, 2016 | 12:18 PM
Rasalas's Avatar
Rasalas
Originally Posted by msdt-99517
This thread got derailed quick
Well get it back on line and contribute!!
Old Sep 29, 2016 | 12:28 PM
Chadmokc's Avatar
Chadmokc
tuffyproducts.com has a stainless steel version that bolts into the side of the tailgate for my 2011, it's universal to lots of models so I would imagine it would work for these trucks or they will have one soon that does. I'm just not sure about the aluminum, I am confused about whether or not I can bolt or clamp to the aluminum with steel/metal without issues.
They also have some cool locking storage options for the guys that were talking about the console vault.
Nothing is listed for the 2017 yet but you can search the 2016 products and get an idea of what will be available.
Old Sep 29, 2016 | 12:36 PM
69cj's Avatar
69cj
Will a 2017 tailgate fit a 2015?
Old Sep 29, 2016 | 12:46 PM
fordmantpw's Avatar
fordmantpw
Very doubtful. The bed is a slightly different size.
Not to mention, the upper trim levels have an electric release and no handle.
Old Sep 29, 2016 | 12:51 PM
RubyRed350Platinum's Avatar
RubyRed350Platinum
I hope your tailgate locks while you build the better houses!!! Better msdt-99517?
Old Oct 1, 2016 | 02:03 PM
KBMWRS's Avatar
KBMWRS
Has anyone answered his question? I'd like to know too.
Is there anything you can do to LOCK the tailgate to the truck???
Old Oct 1, 2016 | 02:13 PM
HouseMouse's Avatar
HouseMouse
Ford sells a trail gate lock that wraps around the pivot point in the hinge area. I have an alarm, the electric lock and now the lower gate lock. Not much else one can do.... it they want it bad enough, they will get it. Just don't make it too EZ.
Old Oct 1, 2016 | 02:33 PM
Chadmokc's Avatar
Chadmokc
I did on post #17. Same thing house mouse is talking about. Tuffyproducts.com has a stainless steel one for the 2011-2016's that should work for the 2017, I doubt anything changed as far as where and how the tailgate mounts. All it would take is a call to them to confirm. It's $25 and I'll buy it when I get my new one delivered.
Old Oct 1, 2016 | 02:41 PM
wb6anp's Avatar
wb6anp
Id put anti corrosion compound between the lock and tailgate to prevent dissimilar metal corrosion.
Old Oct 1, 2016 | 02:50 PM
HouseMouse's Avatar
HouseMouse
Originally Posted by wb6anp
Id put anti corrosion compound between the lack and tailgate to prevent dissimilar metal corrosion.
Bingo! This may help.
https://www.fleet.ford.com/truckbbas...ml/Q-222R1.pdf
Old Oct 1, 2016 | 02:56 PM
Chadmokc's Avatar
Chadmokc
Originally Posted by HouseMouse
Thanks, I was wondering about the stainless steel/aluminum contact 👍 I'll probably squirt a little anti corrosion and still use some sort of isolation tape as well.
Old Oct 1, 2016 | 03:02 PM
HouseMouse's Avatar
HouseMouse
Here is the Ford product for the 2017 and it's made from Stainless Steel and Poly.... Which part is made from what is a good guess.
https://accessories.ford.com/catalog...category/3048/
Old Oct 1, 2016 | 03:04 PM
  #28
wb6anp's Avatar
wb6anp
We have a crane bolted to the bed on our f150 for my wifes scooter that will need to be moved over to the new truck, I will give them a copy of that Bulletin, but will probably end up removing the bolts and seeing if they did it right anyways. Being an acircraft mechanic I am used to preventing corrosion.
1saxman
2004 - 2008 F150
Aug 4, 2015 06:28 PM
TexasA&M
Dec 11, 2013 10:38 PM
Mystic_Cobra
Mar 15, 2009 08:22 PM
Badford
Oct 25, 2004 09:08 AM
hood
1997 - 2003 F150
Dec 12, 2003 07:20 AM
