Wiring issue.
Old Oct 1, 2016 | 06:36 PM
66v8baby's Avatar
66v8baby
The purpose of this troubleshooting test was to disconnect the 904 wire from the voltage regulator to prevent putting 12 volts to it. The easiest way to do that is to disconnect the start switch.
Old Oct 1, 2016 | 06:41 PM
66v8baby's Avatar
66v8baby
An alternate way to do this would be to build 2 jumpers with a male spade terminal on one end and a female spade terminal on the other. Then connect the other two wires to the voltage regulator leaving the 904 open.
Old Oct 4, 2016 | 09:51 PM
F-100project's Avatar
F-100project
I ended up putting a new voltage regulator and the connector to it. With the wire disconnected from the back of the ignition switch. The truck has 14.5v, so I connected everything back up normal and the truck still has 14.5v. So I'm hoping one of those two was the issue or both. Thanks for the help
Old Oct 5, 2016 | 05:53 AM
66v8baby's Avatar
66v8baby
Glad you got it sorted out.
hollywoodusmc
Apr 1, 2016 09:56 AM
jchamp429
Electrical Systems/Wiring
Oct 26, 2014 07:52 AM
imlowr2
Dec 28, 2006 11:03 PM
rick
Jul 16, 2000 01:54 PM
chilly460
Mar 28, 2000 12:34 PM
