6.2L V8 Discuss the 6.2L V8
Air box
Old Sep 26, 2016 | 01:17 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Air box
Has anyone figured out a easy way of removing and installing the cover when changing the filter.
Denny
Old Sep 26, 2016 | 04:18 PM
Chuck's First Ford's Avatar
Chuck's First Ford
loosen screw drive clamp.. removed snorkel from air box.. unclip 3 clips. removed air box cover.
when reassemble.. use Vaseline on inside of snorkel AT clamp.
Old Sep 26, 2016 | 05:55 PM
rvpuller's Avatar
rvpuller
What do you do with the MAF sensor. I had to tape mine because the Ford service personal have damaged the plug beyond repair and I think it has to he removed to get the cover off.
Denny
Old Sep 26, 2016 | 06:02 PM
Chuck's First Ford
I do nothing with MAF or connector... just flip lid over and let it sit..
Old Sep 26, 2016 | 06:09 PM
rvpuller's Avatar
rvpuller
The way mines strapped down it has to be removed to get the cover off, there isn't enough slack in the wire.
Denny
Old Sep 26, 2016 | 10:47 PM
RainDesert's Avatar
RainDesert
I un-clipped my MAF every time for the same reason. Other than that, the change was conventional.
On a side note, the new 2017 6.2 has the filter on the passenger side and it is a different housing:
Old Sep 27, 2016 | 07:38 AM
Chuck's First Ford
I wonder what Ford's reason to change that simple thing.
as mine is an Early 2012.
Old Sep 27, 2016 | 08:38 AM
RainDesert's Avatar
RainDesert
My initial thought was Ford found that it was more quiet? Maybe that whistle folks would get(I did) will no longer be heard?
Old Sep 27, 2016 | 10:02 AM
rvpuller's Avatar
rvpuller
After thinking about this overnight I came up a fix. First the plug was damaged because the wire was tied down so short that it gets pulled on trying to remove and installing the cover so I moved the clip down the wire, I also used some Vaseline on the hose like Chuck suggested an now it's easy to remove.
Denny
Oldanvilyoungsmith
Sep 30, 2016 12:33 PM
DOUG5G
Aerostar
Apr 24, 2006 09:20 AM
Sir_Ham
Aerostar
Feb 12, 2004 02:33 PM
tenorsaxman
Aerostar
Jun 23, 2003 06:43 PM
