2000 Excursion Backup Sensor Replacement ?
Old Sep 26, 2016 | 10:55 AM
poofyo101's Avatar
poofyo101
I am planning on replacing 3 of the backup sensors as they are malfunctioning.
The part number for 2000 Excursion is
YL1Z15K859AA and are 130 each
The 2001-2005 excursion part number is
1L1Z-15K859-AA and is around the same price
The 2003-2005 part number is
4F23-15K859-AA and are only about 20 dollars each.
What is the difference between them? Could I use the 2003-2005 version on my 2000?
Old Sep 26, 2016 | 01:10 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I bought 4 off eBay for $30 total.
Had to use a knife and shave a small tang off them so they fit But other then that they function as expected.
Old Sep 26, 2016 | 01:31 PM
poofyo101's Avatar
poofyo101
Mind sending the link that you bought? So the only difference is the casing which can be altered easily?
Old Sep 26, 2016 | 02:20 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by poofyo101
I am planning on replacing 3 of the backup sensors as they are malfunctioning....
How do you tell when one is malfunctioning?
If the 4F23-15K859-AA works they are about $9/ea on ebay or Amazon (4/$33).
Old Sep 26, 2016 | 02:22 PM
poofyo101's Avatar
poofyo101
you can tell by the clicking noise
Old Sep 26, 2016 | 04:22 PM
pirate4x4_camo
Purchased years ago off eBay so no current link.
Just search "Excursion back up sensor"
Old Sep 26, 2016 | 05:20 PM
R&T Babich's Avatar
R&T Babich
There is also a 3F2Z-15K859-BA sensor for the 2003-2005 Excursion.
A 4 pack of the latest no. 4F23-15K859-AA is $26.
Does anyone know if these are all basically interchangeable after the minor tang trim?
Old Sep 26, 2016 | 06:06 PM
poofyo101's Avatar
poofyo101
This is what I want to know also
Old Sep 26, 2016 | 07:39 PM
Misky6.0's Avatar
Misky6.0
I believe, guess, the diff part #s per year have to do with whether the bumper is chromed or body color matched as the mounting/size is different.
The inner vs outer are also different sensor patterns, I think if you look at them the sensor is different, although they might fit in any spot.
Old Sep 26, 2016 | 07:41 PM
poofyo101's Avatar
poofyo101
So the inner and outer are not interchangable? so there is nothing different wiring wise from any of the years?
dessmo
Oct 30, 2017 06:41 PM
jjbirish
Jan 26, 2008 06:53 PM
rje053103
Nov 5, 2003 01:05 PM
LByellowStang
Oct 3, 2002 01:01 AM
