stalled while driving
Old Sep 24, 2016 | 05:25 PM
cablersdiesel's Avatar
cablersdiesel
Thumbs down stalled while driving
Cruising down freeway and truck stalled out.?? Thought it was the alternator but after towing it home I recharged the 2 month old battery and tried to crank it up and it won't start. Turns over good, battery power is good but won't start.
Old Sep 24, 2016 | 05:29 PM
cablersdiesel
I forgot to mention this is a 2011 F150 with 5.0L V8
Old Sep 24, 2016 | 09:01 PM
Tom's Avatar
Tom
How many miles? Have you scanned it for trouble codes?
Old Sep 24, 2016 | 09:20 PM
fastback89's Avatar
fastback89
There is a fuse that melts in the underhood fuse box that I've been hearing about, might be worth checking out..
Old Sep 24, 2016 | 09:39 PM
cablersdiesel
Thanks for replying guys, I have been away watching football. This F150 has 92,000 miles and the neighbor came over with his cell phone app OBD adapter and said that there were no codes.
Old Sep 25, 2016 | 08:46 AM
ubereal2's Avatar
ubereal2
I think I'd trust a real scan tool over a cell phone adapter.
Do you hear the electric fuel pump turn on when you turn the key run.
Unk Bob
Old Sep 25, 2016 | 10:39 AM
cablersdiesel
yes the fuel pump does run when key is turned, the lines pressures up in just a few seconds and the pump shuts off
Old Sep 25, 2016 | 01:45 PM
pdqford's Avatar
pdqford
Only way to know if the "lines pressure up" is to put a fuel pressure gauge on it.
When you turn the key on, the PCM runs the fuel pump for <2 seconds and then shuts it off, no matter what the pressure is.
When you turn the key to the "ON" position (not the crank position) does the
check engine light come on?
And while you're cranking the engine does the check engine light turn off?
Old Sep 25, 2016 | 02:19 PM
cablersdiesel
OK, when I turn the key to on, all the dummy lights come on then go off except the seat belt and the check engine lights, When I turn the motor over the check engine light goes out.
Old Sep 25, 2016 | 02:39 PM
pdqford's Avatar
pdqford
That's good.
Put a fuel pressure gauge on it.
(Or a scan tool may allow you to confirm fuel pressure).
And pull a COP and rig up a plug wire to it to confirm a hot spark.
Let us know what you find.
Old Sep 25, 2016 | 03:07 PM
cablersdiesel
Thanks guys, I'm gonna let a Ford shop figure it out along with a factory recall and a couple of other things too. I'll let you know back what they find.
Flashjr
1997 - 2003 F150
Feb 19, 2020 03:09 PM
Combatwombat
1961 - 1963 F100 Unibody
Aug 5, 2015 02:01 PM
tdpower
Jan 28, 2012 01:32 PM
Tex1986
1997 - 2003 F150
Apr 23, 2010 09:10 PM
bigworm
Electrical Systems/Wiring
Aug 20, 2006 06:47 PM
