Sponsored by: Auxito
Fuse
Old Mar 17, 2016 | 02:41 PM
Flashjr's Avatar
Flashjr
Fuse
Had a question about where the battery fuse is located and it's number. I just put a brand new alternator on.my truck. Turns out I might not have needed one, switched the battery with the new alternator on and the truck still went dead after it ran for about 10-12 seconds. So some told me it may be the battery fuse but I don't know which fuse it could be.
Old Mar 17, 2016 | 03:06 PM
Sam I Am's Avatar
Sam I Am
Owner Manuals | fleet.ford.com
Old Mar 17, 2016 | 07:00 PM
Bluegrass 7's Avatar
Bluegrass 7
A voltmeter is your friend rather than just guessing at things.
If there is no voltage on the heavy lead from the battery to the alternator, the big fuse/circuit 175 amp rated is open.
Next, there is a 20 amp inline fuse for the alternator.
The motor won't stop running if either of these fuses are open unless the battery is near dead.
The motor control does not come though these fuses.
All circuits are direct from the battery through separate fused circuits to the distribution boxes.
You have something else going on.
The big fuse may be on the fire wall as part of the start relay circuit or it may be an inline fuse link in an insulated shell.
Good luck.
Old Feb 19, 2020 | 03:09 PM
Markken's Avatar
Markken
How did my reply end up here...
1sraider
19
Nov 28, 2018 04:32 AM
Bubba Hines
Dec 19, 2015 09:06 PM
tdpower
Jan 28, 2012 01:32 PM
bigworm
Electrical Systems/Wiring
Aug 20, 2006 06:47 PM
