Sponsored by: Real Truck
battery cut off switch??
Old Aug 21, 2003 | 08:12 PM
cockeyed00's Avatar
cockeyed00
I just wanted to know what you can use a battery cut off switch for and where I could place it( under hood or in cab)?
thanks
oO
Old Aug 21, 2003 | 11:07 PM
Yeti's Avatar
Yeti
You could use it to kill power to the stater, pretty much what it is made to do. Depnding on how long a cable you want to run, you could put it anywhere you want.
We run them inside on race cars, but I have seen them mounted under the hood on street rides.
Pretty much wherever you want to put it, that you dont mind drilling the hole to mount it.
Old Aug 22, 2003 | 02:25 AM
RRMike's Avatar
RRMike
Slick cheap anti theft device. Moron thief gets in and turns key on and.........nothing. Unless you put it after the solenoid then all the bells and whistles would come on but it would never crank. That would be great too.
Old Aug 23, 2003 | 02:37 AM
cockeyed00's Avatar
cockeyed00
does anyone have one of these in their in their cab? If so, where?
what gauge wire do I use for starter?
thanks
oO
Old Aug 23, 2003 | 07:55 PM
99f350sd's Avatar
99f350sd
Just take the small wire off the solenoid the one thats gets 12volts when the key is turned to start .. extend that wire to the place where you want a sw run a wire back to the solenoid where you removed the wire and wha la you can leave the keys in the truck but make sure you hide the sw well. use the same or one size larger for your wire extension.
Old Aug 31, 2003 | 12:20 PM
TJ-Ranger's Avatar
TJ-Ranger
I have a cut-off switch on my MX6. A great devise..and located in the car so I have control of it. I'll be putting one in my truck soon too.
Old Sep 2, 2003 | 02:10 AM
cockeyed00's Avatar
cockeyed00
Thanks everyone.
I found a spot for it. Next to the fuse panel and left from the data com connector. I bent some of the metal drilled a hole and placed the switch.
oO
bigtexan99
Apr 7, 2014 02:08 PM
boaterbob
15
Jan 7, 2011 03:17 AM
m wolf
Aug 14, 2010 10:01 AM
78 Ranger
Electrical Systems/Wiring
Jan 27, 2008 02:19 PM
fatfenders
Jun 30, 2003 02:01 PM
