Quick steering coupler question
Old Sep 24, 2016 | 02:33 PM
NashvegasMatt's Avatar
NashvegasMatt
I've Read the how to's and I get how it's done but it looks like most pull the entire steering column out. Does this have to happen or can you just loosen the bolts on the coupler/shaft and pull the steering wheel off to swap
Old Sep 24, 2016 | 02:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2WD: You don't have to remove the steering wheel or the steering column to replace the coupler.
Shown as 3A525 in pic:
Old Sep 24, 2016 | 02:44 PM
NashvegasMatt
Good to know. I got a new steering wheel so I was gonna do both at the same time.
Is the dorman kit they sell at the autostores as good as anything else? Quality wise there doesn't seem to be a significant difference
Looks like most people use the doorman 31000 because the 31002 seems too small. Here's what I'm working with. Should the shaft end be this curved...? Seems warped and unusually shaped for this function. And then maybe yet again I just don't know what I'm talking about.....almost looks like the PO installed it wrong who knows how long ago....
I'm gonna fire up the old google machine and see if I can find a clean correctly installed one to compare
Old Sep 24, 2016 | 06:11 PM
FuzzFace2's Avatar
FuzzFace2
Looks bent to me.
See the 2 different size metal pins that fit into the cut outs of the wheel side of the coupling? They should be up inside that cut out so if the rubber part fails the pins will hit the sides of the cut out.
You will have a lot of play in the wheel but will not lose steering all together like you would now.
I would look into why / how it got bent as it would have taken a lot of force to bent that part.
I would not go hammering on it to get it flat again with out pulling the shaft out of the column as you could hurt the bearings (top & bottom) and other things.
Dave ----
Old Sep 24, 2016 | 06:52 PM
NashvegasMatt
Looks bent to me.
Dave ----
So every picture of every one I see is flared like that?🤔.... I don't understand how this could happen
Old Sep 24, 2016 | 07:00 PM
SmokeyBear31's Avatar
SmokeyBear31
It's not bent. Look at the rubber, it is misshapen. When you put it back together, the pins will end up inside the cutouts.
I used the Dorman kit too, here's a quick and dirty how to on how to change them.
Loosen the two bolts under the dash that hold the steering column but don't remove them completely.
remove the bolts that hold the bottom of the column to the floorpan.
remove the crossbolt in the coupling.
remove the four bolts that go through the coupling.
get back in the cab and pull back on the steering wheel. This will separate the column from the coupler.
Remove the coupler from the steering box.
Then you can take it to the bench and replace the rubber.
Install is the reverse.
Old Sep 24, 2016 | 10:49 PM
spdcat72's Avatar
spdcat72
The shaft flange is fine. The rubber is shot! The Dorman rubber replacement works fine. You have to completely remove, not just loosen, the 12 pount bolt on the steering box side of the coupler to slide the coupler off the splined input shaft. There is a cutout in the shaft that the bolt fits into.
Gabrielc1925
Oct 13, 2014 04:51 PM
countryshiz87
May 26, 2012 02:38 AM
n8mojo
Aug 17, 2004 12:19 PM
banditjax
Oct 21, 2003 02:37 PM
