Just bought a 1994 7.3L turbo diesel. It is a 4x4 dually
The head lights flicker on and off after they have been on for a few minutes. This happens at all rpm and even when truck is off with lights on. There's massive amounts of wiring with covering to remove to look for bad wires and if it's covered it shouldnt be worn right? Also I see a 2 relay box next to the original power distribution box. Is this an add on modification? The lights work without either of these relay in place. I've check and cleaned a few grounds. No difference. Anybody have a simpler plan of action other that ripping out all the wire coverings.
probably a bad switch and connector.
the headlight switch is rated for about the power the lights use, and if someone drove for a long time with the high beams on, it will overload the switch and start melting things.
remove the connector off the back of the switch and inspect closely. if there is any discoloration or melting at all, replace the switch and connector.
i added relays to my 88's headlights back in 1990 after the stock switch and connector burned up. the power now goes from the batteries through the relays to the light bulbs and the only thing the headlight switch powers is the low current side of the relay.
I did some more grounds and got nothing. I guess its not pointless because I'm eliminating future problems... Maybe.. I plan on driving this thing hundred of thousands of more mile. It has 102k now. I just read about the switch and connector and I will check that out first chance I get. Do you have to pull the dash?
Ok thanks I'll be looking into it in the next couple days. How long do the replacement switches and wiring last? Prob not looking to do the upgrade with relays right now.
if you do not use highbeams and do not add extra lights, you should have no problems getting 10 years out of a light switch.
mine burned up within 2 years because of the added lights for the snow plows.
Ok had some time to play with it...
Took out gauge cover to get to headlight switch. Turns out he harness and switch were replace once already and I replaced them both again. Problem solved. However I will be going back in to do the relay upgrade. After seeing the switch had already been replaced once I decide I would do the upgrade for sure. Thank you so much for your help diagnosing the problem!!! I love this sight
Has anyone ever the switched the old interior lights out with an led bulb? Do they make them? I'd like brighter cab lights and would do the dash cluster lights too
If you really want to upgrade the dome/map light, get a housing from a '96 or later truck. They ditched that bigeffin' heavy metal thing that gets hotter than get-out with a stylish plastic one with "festoon" style bulbs. I did this with both our '95s, and put cheapo eBay LEDs in all of them, and it's a vast improvement. Just make sure to get a dimmable LED for the center dome light. Caveat - with the new style light housing, the tabs for the lens are VERY delicate, so be careful removing/installing it.
Haven't done anything with the door interior lights yet.
Just do relays, it's easy and worth the effort. These headlight switches and wire gauge is marginal for the load to begin with, add 30 years of age, wear, and PO hackjobs and you can have a problem. I suggest measuring voltage drop to the headlights to give you an indication of wiring condition. In any event, headlight relays (and Cibie housings with H4 bulbs) has been one of the best safety and comfort upgrades I've done to the truck. No idea how I drove several of these trucks around for so many years with junky wiring and headlights that were like holding a candle in the wind.
