5.0 motor help
Old Aug 21, 2003 | 07:37 PM
tmryan362's Avatar
tmryan362
5.0 motor help
Have a 89 f150 with a problem. It has a 5.0 automatic. Truck starts and runs ok until it hits operating temperature; then motor starts to break up. Have checked egr and it is ok; have checked pvc and distributor all ok.
Any ideas on what to look for next
Thanks, Tom
Old Aug 21, 2003 | 07:42 PM
luckild's Avatar
luckild
5.0 motor help
What exactly is motor break-up?
Old Aug 21, 2003 | 07:47 PM
tmryan362's Avatar
tmryan362
5.0 motor help
By break up I mean a bad miss. Feels like not all spark plugs firing. Blowing dark smoke out of tail pipe. Stalls/ can smell cat converter cooking. Until it reaches operating temperature truck runs ok; once hot the truck runs like cr*p
Old Aug 21, 2003 | 09:17 PM
Duderoy's Avatar
Duderoy
5.0 motor help
Check your O2 sensor. Your truck only uses it in closed loop which occurs at full warm up. While it is warming it is in open loop and uses all the other sensors to determine a pre-programmed injector duration, but the O2 sensor does not take over until it is warmed up.
Old Aug 24, 2003 | 06:22 PM
tmryan362's Avatar
tmryan362
5.0 motor help
Not o2 sensor. Have also eliminated egr and pvc valve. Problem only occurs after truck has reached operating temperature. Truck runs very rough, stalls at idle. Seems to be getting a very rich mixture. Cat converter appears to be overheating,(excess fuel being dumped form cylinders?)
Any fresh ideas??
Thanks Tom
Old Aug 24, 2003 | 07:03 PM
steve83's Avatar
steve83
5.0 motor help
Read this thread and post the code definitions.
Also, see if you have gasoline in the red vacuum line to the fuel pressure regulator.
Old Oct 9, 2003 | 05:34 PM
Trampus's Avatar
Trampus
I had similar problem ended up being fuel pump losing pressure after running engine for 15 or so minutes
Old Oct 11, 2003 | 06:29 AM
KB ZILLA's Avatar
KB ZILLA
Check your MAP sensor on the firewall by the heater box. Check the vacuum connections to it also.
I had a similar problem and found a bad hose going to the MAP, it would run good the first few minutes then start blowing black exhaust out and running rough.
Old Oct 11, 2003 | 03:16 PM
Hit Man X's Avatar
Hit Man X
I'd check your O2 sensor again...how did you check it? They are only good for about 50K mi also.
Then maybe the coolant temp sender for the computer. I believe it is a little black thing with 3 wires running to it.
Tom Callan
Nov 2, 2014 11:43 AM
tcough
Nov 19, 2010 02:55 PM
tip49
Dec 12, 2008 03:25 PM
WoodN1_76
23
Apr 19, 2008 02:43 PM
Tom Cullen
Dec 31, 1999 05:29 PM
