Transmission rebuild question
Old Sep 23, 2016 | 08:45 PM
Sevrock's Avatar
Sevrock
I have a 1994 f150 193k of hard pulling miles with 302 gas and not sure if aode or 4rw70 transmission here's the story. the temp gauge for tranny says it running way high and the moter feel way hotter then before my overdrive on the shifter is flashing intermittently but most every time I drive it. The trans fluid looks good yet but it's starting to smell burnt so I'm getting a trusted trans guy to look at it. I'm thinking it's needing to be replaced. My question is one, do you agree it will need work done and two if so can anyone think of anything else a guy should get done while the transmission is off the truck? I'm thinking new rear main seal change transfer case fluid, can anyone think of somthing else I should do while it's off? Any help is appreciated alot.
Old Sep 24, 2016 | 12:11 AM
phoskins's Avatar
phoskins
Has the trans fluid been changed regularly throughout the 193k?
Old Sep 24, 2016 | 06:44 AM
My4Fordtrucks's Avatar
My4Fordtrucks
There are a few trans gurus on here that can help you diagnose the problem but I believe they would tell you to check for codes first. The OD light flashing is the same thing as the check engine light coming on.
Old Sep 24, 2016 | 07:45 AM
Sevrock's Avatar
Sevrock
No clue on the fluid change. Guy I bought it from worked at a bank so probably not. I have put about 30k miles on it and changed the fluid once when I bought it. I thought about the codes but I don't have a scanner and was going to bring it up to the my transmission guy. How would a guy check old school codes line that? Count the flash intervals of the overdrive light?
Old Sep 24, 2016 | 10:04 AM
My4Fordtrucks
I'm not sure since I have never done it. My suggestion would be to do a search of how to retrieve codes since it has been covered many many times.
jtorsey91
Dec 17, 2015 05:42 PM
keeptheedge144
Oct 27, 2012 02:04 PM
Scaper
Apr 3, 2012 03:54 PM
yonder in ky
Feb 18, 2012 05:06 AM
rmelki
Feb 19, 2003 08:47 AM
