Fueling issue?
Old Sep 23, 2016 | 02:37 PM
Donny_D's Avatar
Donny_D
Fueling issue?
Hey all so I went out this morning and started the truck it started slowly (cooler morning) not much thought put into it. Made it around the corner and truck died.
I was going to see if anyplace in town had the fuel rail
Passenger Side Fuel Line for Ford 7.3L Powerstroke (99-03)
Wasn't able to make it and from what I have seen online they don't have it at Orileys anyhow.
Now I'm sitting with a new truck that won't stay running due to an unknown fueling issue. Any help where to start looking would be amazing!
Old Sep 23, 2016 | 03:57 PM
knottyrope's Avatar
knottyrope
what is fuel pressure at idle and at WOT?
Do you have a scanner for codes?
oil level ok?
Old Sep 23, 2016 | 06:32 PM
Donny_D's Avatar
Donny_D
So after opening the fuel filter bowl changing the filter also 2 gallons of oil she started right up... I checked oil at the dealership and there was oil plus I drove it 3 hours with no issues I have no puddles under truck so I have no clue why she was 2 gallons of oil low...
Old Sep 23, 2016 | 06:41 PM
z31freakify's Avatar
z31freakify
Time for Injector O rings. Check your fuel filter to see if its not black. Also check the inside of the down pipe for any signs of oil, if so turbo rebuild is on the way.
Old Sep 23, 2016 | 11:40 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Bingo. May all of our problems be so easy.
Leaky injector o rings letting oil mix into the fuel is a rather invisible way to lose oil. As noted above a black fuel filter is the giveaway. Blown turbo seal often shows as oil out the tail pipe. Also check the radiator degas/overflow tank for oil. Hopefully it's not that as it would point to cracked injector cups.
Old Sep 24, 2016 | 04:01 AM
Donny_D's Avatar
Donny_D
Will I replaced the fuel filter today the fuel in the bowl was black with oil. Injector rings next weekend woohoo thanks gents!
Miner9914
Jul 28, 2019 12:17 AM
caedo
Mar 16, 2014 10:10 AM
PJ-Hunter
31
Nov 9, 2013 11:23 AM
Crewcab Turbo
Feb 6, 2012 09:02 AM
mark460
Nov 10, 2011 03:19 PM
