Replacement key
Old Sep 23, 2016 | 01:40 PM
NashvegasMatt's Avatar
NashvegasMatt
Replacement key
So my truck only came with one key.... the all metal style. I would rather have one that has a rubber grip on the end... even plastic would be ok. I've search online but all I see is the all metal style. Any suggestions?
Old Sep 23, 2016 | 01:59 PM
RichS2659's Avatar
RichS2659
Any lock shop should be able to make up a blank like what you want. If not you can get the little cover for it.
Old Sep 23, 2016 | 02:25 PM
Coastal68's Avatar
Coastal68
Just curious: Why do you want a key with the plastic/rubber grip?
Old Sep 23, 2016 | 02:28 PM
NashvegasMatt
Because for work I have lots of keys and they all look alike. Lol. Would just make it easier to find...
Old Sep 23, 2016 | 06:57 PM
JEFFFAFA's Avatar
JEFFFAFA
Actually the square headed and double sided Ford key should be easy to pick out IMHO. While they look the same, the tips of the keys that slide in the lock are different between the factory Bump key and the later model ones that had the black rubber grip. As far as I know you are stuck adding a cover for it yourself. Or maybe that DIP stuff I've seen. Meant really for dipping the handle of tools in it to create a cover or grip.
Old Sep 24, 2016 | 01:15 PM
jbbott's Avatar
jbbott
I was able to get copies made for my 72 at Home Depot. Wasn't rubber coated but they had tons of key options.
Old Sep 24, 2016 | 01:16 PM
jbbott's Avatar
jbbott
Multiple colors at Home Depot, so it would make sense to get a different color key
Old Sep 24, 2016 | 02:49 PM
NashvegasMatt
Ironically I work there. Options from the vendor hillman-coleman are metal only at this time
Old Sep 24, 2016 | 02:58 PM
HIO Silver's Avatar
HIO Silver
Apply Plasti-dip... the same stuff which can be used for tool grips.
sne43
Transit Connect
Jul 8, 2019 02:22 PM
Pennsyltuckian
Jun 13, 2018 10:15 PM
Thorium
2015 - 2020 F150
23
Nov 17, 2016 12:34 AM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
GSmack
Transit Connect
Jun 3, 2013 08:18 AM
