Overdrive Chatter
Old Sep 22, 2016 | 11:25 AM
50th ann's Avatar
50th ann
Smile Overdrive Chatter
My 2010 F-150 with 170,000 miles - 6R80 Transmission is starting to chatter while shifting into overdrive. It lasts about two seconds and then all is well. I'm sure it will get worse. Any suggestions will be appreciated.
Old Sep 22, 2016 | 03:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How old is the ATF? Old fluid can cause this. So can old spark plugs and/or ignition coils.
Old Sep 22, 2016 | 04:25 PM
50th ann's Avatar
50th ann
Smile Transmisson Chatter
The transmission oil & filter have 63,000 since the last change. The spark plugs have 30,000 miles on them. The coils are original at 170,000 miles.
The chatter does not happen if I put the transmission in Tow/Haul mode.
Thank you for the help
Old Sep 22, 2016 | 04:51 PM
Mark Kovalsky
I recommend changing the ATF first. If that doesn't fix it, consider the possibility that one or more coils is getting weak.
Old Sep 22, 2016 | 08:54 PM
meborder's Avatar
meborder
There have been a few reports of torque converter problems with the 2009-2010 f150's. These years are programmed with a very soft torque converter clutch engagement which appears to be very hard on the fluid and clutches.
That being said, you should notice the chatter slightly after the 2-3 shift as the truck will lock the converter very early in 3rd gear.
As a test, you can start the truck out in 3rd. This will let the truck take off in 3rd and eliminate all the other variables in the trans except the torque converter clutches. The truck will lock the converter very early in 3rd even with the pedal to the floor, so if it is the clutches going bad, you should notice it when it tries to lock up. If it is there all the time, then it is probably something else like an ignition problem as mark mentioned. If you only feel the chatter when the converter locks up, then a fluid exchange might fix it.
If all they did was drop the pan and refill, then you only got about 1/3 of the old fluid out when they changed the filter. 2 more pan drops and refills will get 90% or better of the old fluid out. Being as this truck has a thermostat in the cooler circuit, a line off exchange at home wont work, so the only other practical way to get the fluid exchanged is with a heated flush machine.
There are some quickly lube places that have a machine that hooks up to the filter inlet and exchange the fluid that way, so that might be another option.
Just some things to try and think about.
Old Sep 23, 2016 | 06:18 PM
50th ann's Avatar
50th ann
Smile Transmission Chatter
I can make the problem go away by putting the transmission in Tow/Haul Mode or by driving around in 3rd gear. Does that suggest what it might be?
Old Sep 24, 2016 | 10:29 AM
meborder's Avatar
meborder
Im far from an expert, but that would tell me the torque converter is probably not your issue.
Tow haul changes shift points so it would go into 6th later than normal.
I'd probably Change fluid and hope that's it, but i wouldn't rule out ignition issues.
Old Sep 26, 2016 | 06:51 PM
50th ann's Avatar
50th ann
I took it to the local transmission shop. They tell the 6R80 Ford transmission is a good transmission although they have seen a few torque converter issues.
They want $1,100.00 to replace the torque converter, new filter and fluid change. Fair enough I'm going to let them do it. I'm hoping to drive that truck at least 250,000 miles. My 1998 F150 made it that far. Time will tell.
Thanks for all the advice
2006FOMOCO
Oct 15, 2023 06:12 PM
HST
1997 - 2003 F150
58
Sep 9, 2023 02:13 PM
drew_goeke
2004 - 2008 F150
37
Jan 12, 2022 12:42 AM
slfd1717
1983 - 2012 Ranger & B-Series
Apr 7, 2013 08:02 PM
bfree65
2004 - 2008 F150
Jul 10, 2011 10:05 PM
