Small block ranger swap
Old Sep 21, 2016 | 11:37 PM
Mick.longacre's Avatar
Mick.longacre
I have a pipe dream of swapping my 2.3 ranger, 95 type, into a small block v8, preferably carborated. I want to make her into a toy, I live in the Rockies and want an off-road beast, so I want to put in three quarter ton diffs and need to be able to make them turn. Has anyone done this? And words of encouragement?
Old Sep 22, 2016 | 12:54 PM
spooktn's Avatar
spooktn
Well thinking about the size of the truck and a V8 swap,,,I think I would try and find a old school 302 motor and trans and shoehorn it in,,,, of course you may have to do some fab work on motor and trans mounts,,, if you can get a older 302 that was not computer ran it would solve a lot of troubles,,, just a simple hot over to the distributor and a carb instead of injectors and you would be in business,,, a old school carb and distributor ran engine would be a big horse power upgrade !!!!
Old Sep 22, 2016 | 01:53 PM
Mick.longacre
I agree. I'm not afraid to weld in new mounts or cut into the firewall, I like welding. I definitely don't want a computerized motor, I suppose I'll just have to measure the bay and see what I can shove in there, so long as I can get headers in there, I can cut into the hood for the intake, a beast of a carb should allow it to sit above the hood level. She'll be lifted so if I had to I can cut into the wheel well as well.
Old Sep 22, 2016 | 08:16 PM
spooktn's Avatar
spooktn
Sounds like a plan,,all it takes is time and money LOL,,, I dont think I would go bigger than a 302 because of weight and handling,,, but your truck go bigger if you want,,, but a old school 302 with a prefromance cam and a good duel feed carb and the little Ranger would scream !!!!!!!!!!!!!!!!!! maybe some headers too !!!! and duel exhaust of coarse
Old Sep 23, 2016 | 02:52 AM
Mick.longacre
But of course. Probably a stroked crank too...I could make a long a$$ list...
Old Sep 30, 2016 | 02:01 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Have a look here:
Ford Ranger V-8 Engine Swap
Old Sep 30, 2016 | 06:17 PM
spooktn's Avatar
spooktn
wow that is a lot of info,,,answers a lot of questions atta boy Whatsachevy !!!!!!!!!!!!!!!!!!! that should help poster out !!!!!!
Old Sep 30, 2016 | 09:54 PM
WhatsAChevy?
Hope it helps. It is the most comprehensive info that I know of. When My '97 (purchased new in '96) turned 100k, I wanted to do the swap. When it hit 150k, I decided it was time. When my grandson and i did it, we retained the engine's factory exhaust manifolds (port machined to match the machined heads for flow reasons) due to headers causing too much heat under the hood. Way too much plastic in the engine bay of these 1/4 tons. Secondly, we opted for an HEI distributor set-up for simplicity, avoiding all of the DSII wiring issues. My grandson didn't know it at the time but when it was finished, i was giving it to him. He lives in S.C. where there is no emissions testing in his county. (He was spending the summer with us in Ohio). Long story short, he's driving a slick little flareside with a 302, 15x10 chrome reverse rimmed, dual exhaust Ranger with about 225,000 miles on the odometer the last time we talked. (I won't mention the speeding tickets....dern kids !).
Old Sep 30, 2016 | 10:46 PM
WhatsAChevy?
Is it a TTB 4X4? If not, the expense would certainly be pricey.
For the differentials, I would look towards the Jeep world. Many Jeep driveline parts will assimilate into B-Series trucks.
3/4 ton differentials ?
You are reaching for a "high $ elevation" conversion (Colorado joke).
Ford and Chrysler share a lot of specifications (that is why AMC used both of the manufacturer's parts for so many years).
mudslinging79
Bronco II
18
Nov 22, 2010 03:31 PM
BIG-COUNTRY
Nov 29, 2005 05:47 AM
mattd860
Engine Swaps
Oct 12, 2004 03:06 PM
BroncoRoadKill
Engine Swaps
Sep 22, 2003 05:17 PM
79F2504x4
Jan 20, 2002 08:56 PM
