Tail light malfunction
Old 09-21-2016, 12:55 PM
Mick.longacre's Avatar
Mick.longacre
Mick.longacre is offline
1989 f150 5.8 has absolutely no tail or brake lights. Blinkers work, but tail lights don't. Can someone send me a schematic? Also, has anyone thoughts on this? Apparently the fuses are good, but as this is my roommates truck, I don't really know where to start.
Old 09-21-2016, 04:29 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
I dont have diagrams for this, but see if the emergency flashers work. If they do try the brake lights again. Sometimes this will clean up dirty contacta in the MFS/multifunction switch.
Sign up for a free account at bbbind.com and you can pull up the diagrams
Old 09-21-2016, 04:34 PM
Mick.longacre
So the signals do work, but the hazards and brake lights do not... They are new bulbs, so I'm somewhat confounded.
Old 09-21-2016, 05:40 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Just took a quick look online and stop and hazards are on the same fuse. Fuse 1 and it's a 15 amp
If the cruise control cuts off when you tap the brake the fuse is OK.
The online diagrams dont show it, but i think the hazards and brake lights are wired to the hazard flasher.
Old 09-21-2016, 07:46 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
If the turn signals work, but the Hazards don't, I'd suspect an issue with the hazard system or the turn signal switch itself.
Old 09-21-2016, 11:28 PM
Mick.longacre
I just went out and rechecked her fuses, fuse one is fine. As for the switch, I changed the brake switch itself so it has to be deeper than the switches. As for the cruise, I'd wager it hasn't been connected in twenty years. Tomorrow I'm going to start with the hazard flasher and go out with my multimeter and just start chasing the wiring from the light assembly to the engine and drill blindly hoping to strike oil. I'll definitely be sure toilet you guys know what I find out. Thanks for all the help.
Old 09-22-2016, 01:50 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Yeah, could be as simple as a bad hazard flasher. Have fun.
Old 09-22-2016, 06:21 AM
DrZoom's Avatar
DrZoom
DrZoom is offline
Do the dash lights work? If not, it could be fuse 4 or fuse 17. I went in circles for a long time because I thought I was checking the right fuse, but I wasn't. It never hurts to go through the entire fuse panel occasionally and make sure everything is in order. I wasted a lot of time under the truck looking for shorts before checking all my fuses.
Old 09-22-2016, 11:53 AM
Mick.longacre
Yea, I'm going off of what she told me. I plan to start with the fuses and go from there. Does anyone have a fuse diagram for this old girl?
Old 09-22-2016, 04:01 PM
madpogue's Avatar
madpogue
madpogue is offline
Fuse assignments are in the owner's manual. As for a diagram, there isn't just one. It's a whole book, the EVTM - Electrical and Vacuum Troubleshooting Manual. Usually available for most model years used on eBay, and worth it's weight in... well... very expensive steak, perhaps.
As for the taillights, also check the front parking lights, and the dash lights as mentioned. Park/tail lights are on a separate circuit from stop/turn/hazard lights, so you may have more than one issue.
Old 09-23-2016, 02:54 AM
Mick.longacre
So there is not power at the fuse. What exactly does that mean?
Old 09-23-2016, 06:34 AM
Lead Head's Avatar
Lead Head
Check all the fuses both under dash and underhood. Fuses can often power other fuses.
Old 09-23-2016, 07:19 AM
madpogue's Avatar
madpogue
madpogue is offline
Which fuse does not have power?
Old 09-23-2016, 08:31 AM
DrZoom's Avatar
DrZoom
DrZoom is offline
I learned that the hard way. Fuse 17 was powered by fuse 4 in my case. I tore the dash half apart before I realized that.
Old 09-23-2016, 08:44 AM
madpogue's Avatar
madpogue
madpogue is offline
Pretty-much every fuse in the interior fuse panel is energized by a fuse in the underhood fuse panel. Yet another testament to the value of the EVTM.
Quick Reply: Tail light malfunction
