advice needed: alternator output
Old Aug 21, 2003 | 04:48 PM
meck1's Avatar
meck1
Is there a way of testing, while it is in the truck, what the output is from an alternator? I've got an '87 F250 with the 300 engine. I don't think the alternator is stock, and I would like to find out what its output is as I'm adding on some accessories. I don't want to go to the expense of a higher output alternator if the one in the truck will do the job. Any help you can give will be appreciated.
Thanks
Old Aug 21, 2003 | 07:25 PM
Mil1ion's Avatar
Mil1ion
You can check voltage, but not amperage without a special tester.
Take it to an auto parts store as they usually test charging systems for free.
Old Aug 23, 2003 | 07:46 PM
stockcar92's Avatar
stockcar92
Why cant you put an amp gauge between the alt output and battery. Remeber amp gauges have to wired in series they cannot parralel the circuit. Also some alternators have the amperage rating on them it is stamped in the case.
Old Aug 23, 2003 | 11:05 PM
Franklin2's Avatar
Franklin2
If you wanted to test it fully, you would need a dummy load of some sort that could sink a lot of current, so you could put it through it's paces.
LipschitzWrath
22
Aug 14, 2017 05:22 AM
carver94f350
32
Apr 9, 2012 08:39 PM
midnight1957
2004 - 2008 F150
Aug 6, 2008 10:50 PM
sdetweil
Jun 13, 2008 09:10 PM
Commandohorn
May 5, 2006 10:43 PM
