Rough idle issues
Old Sep 18, 2016 | 07:48 PM
Rij1's Avatar
Rij1
Rough idle issues
So, I did a tune up cause my idle was getting rough. The engine was very shakey and seemed to be missing. I replaced plugs, wires, cap and rotors and it didn't help. I did notice that the actual carb was loose and moving so I tightened the bolts. Nothing seemed to change. The engine seems to smooth out with higher rpm but it's still shaky. Anything below 1100rpms is very rough. I have the 4.9L 1 bbl carb and the smog crap. I tested for vacuum leaks with carb spray and didn't seem to find any. I don't know what else to do and can't have the truck down since I use it for work and to pick up my kids from daycare. I did disconnect the battery and ran a couple tank of gas with seafoam but with now change.
Also, is there a manual for this carb I can download? I can't seem to find one.
Thanks, Rudy..
Old Sep 18, 2016 | 07:58 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Try this for 1bbl info.
Carter YFA 1bbl - ???Gary's Garagemahal
Old Sep 19, 2016 | 02:26 PM
Rij1's Avatar
Rij1
Thanks. But My carb is the later 1bbl with the electric parts.
Old Sep 19, 2016 | 02:33 PM
ctubutis's Avatar
ctubutis
So, it looks like you have a computer-controlled ignition & fuel system, this was in 1985 & 86 (wish you would have given the specs in your opening post).
First thing to do when diagnosing any computer-controlled engine is to ask the computer what it thinks is happening, here's one write-up on how to do that:
Ford Ranger - Testing EEC-IV Equipped Engines
Old Sep 19, 2016 | 06:59 PM
maytag906's Avatar
maytag906
Check for a vacuum leak. Line off, or if the carb was loose, maybe the base gasket is bad.
Old Sep 19, 2016 | 08:00 PM
WhatsAChevy?
My second forensic detective work would be to inspect the internals of the carb for cracks and or fractures regardless of the model of carb.
hayes2go
May 27, 2024 05:19 AM
2010Iron883
Feb 24, 2011 08:43 PM
77F-150
Jul 25, 2010 05:53 PM
F250Dave
Sep 28, 2006 08:17 PM
fordnut71
Nov 29, 2003 05:13 PM
