Alcohol
Old Aug 21, 2003 | 02:07 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Alcohol
You guys think it would be safe for me to dump a gallon of rubbing alcohol into every 10 gal. of 89 to boost performance at a cheaper price then octane booster? Trucks a 86 F-150 4x4 with a 300 and a 4 spd. man. just lookin for more power.
Redneck-Cowboy
Old Aug 21, 2003 | 03:06 PM
bubbaf250's Avatar
bubbaf250
Alcohol
No, it would not be safe. Rubbing alcohol is 30% water and 70% alcohol.
Octane boosters do not "boost performance" anyway.
Advancing the ignition timing can give a little more power, so if you advance the ignition timing to the point of serious pinging, then an octane booster (to relieve the pinging) might help.
Old Aug 21, 2003 | 05:05 PM
only210Kmiles's Avatar
only210Kmiles
Alcohol
Please explain "advance" and "retard" timing. I think I know what it means. When you advance the timing, the spark occurs sooner vis-a-vis the position of the piston in the cycle. When you retard the timing, the spark occurs later in the cycle. In other words, to go from 6 degrees BTDC to 2 degrees ATDC is to retard the timing?
Is that right?
Old Aug 21, 2003 | 07:31 PM
bubbaf250's Avatar
bubbaf250
Alcohol
Yes, that is correct.
Redneck-Cowboy
4 Cylinder Engines
56
Nov 5, 2004 12:55 PM
Redneck-Cowboy
Exhaust Systems
20
Jan 4, 2004 09:24 PM
Redneck-Cowboy
Dec 1, 2003 04:23 AM
Redneck-Cowboy
Sep 11, 2003 03:50 PM
Redneck-Cowboy
Sep 5, 2003 07:18 PM
