IDI, the right choice?
Thanks,
I personally don't mind going 40-55mph while towing. It's just the right/smart thing to do. Seen a few videos on YouTube of guys going too fast. Tire pops. Rv goes over. High winds, rv goes over etc.. I'll have family back there. No way would I go over 50/55
You should be able to easily get 225hp, 340 torque with a 7.3 turbo.
I'm on the same boat as your friend when it comes to spending whatever (over time). If this is the case, go with the idi. 10-15k will get you far.
Tell your friend to put a gear splitter. Not really necessary for 5k lbs, but his budget says why not. I used to own one on a 6.9. Fun times.
with a manual 4 speed i get / 15 city / 25 country / 20 highway / mpg
hauling ? yep it'll pull my boat like it's not even back there ..
loaded with wet coal ~ 6k lbs? the steering is squat but it's fast as ever ~ 70 - 75 and hauls it with ease ..
i don't know much about turbos .. but there are many available for whatever you need to do .. depending on what your driving preference / needs require ..
normally 200 hp is standard with these motors .. near 300 is possible .. certainly .. but not unless you're willing to spend some $$ in parts to get there ..
you can probably build a boss truck for half your budget .. if you do the build yourself .. and spend the other 7k on monster truck tires !!
get a manual transmission if possible .. and yes with this budget get a brownie under/over
I've hauled 18K before(6 tons of hay + 4K of trailer), and that was heavy. I wasn't going to be going 75 with that; I managed 55 most of the way, but that was less about power and more about load stability going around curves. I think I still averaged like 8-10 MPG with that load.
The GVOD will give me a 2nd-over(though the stock computer will lock it out until like 25 MPH), 3rd over which is slightly lower than 4th, and 5th over. 4th over is exactly the same as 5th.
It's a fairly stout unit and works nicely as long as you know it's limitations:
1. Change it's oil every 30k.
2. It will not do overdrive in reverse. You will get grinding noises if you do so*
3. Never engage it in 4x4... If it can engage, front and rear gearing will be at different ratios. *
3. It's rated for a good amount of torque, but with the gear multiplication effect, using it in too low a gear can damage the conical clutch inside. *
4. It is hydraulically actuated internally(using an external solenoid), and needs to build up pressure before engaging(i.e. going a few MPH)*
All the *'s above are moot in a normal GVOD installation - there is a computer box which prevents you from doing any of those. Of course, I did something wrong a few years back, shorted it, and bypassed the whole thing with a switch.
I always drive(loaded) with my eye on EGTs, and water temps. Pulling some long(multi-mile), hot grades I've actually had to back off because my water temps were going over 220F, my safety range.
And, well, I'm not sure a new truck would do too much better -- radiator size is radiator size -- though they might well have an auto-fueling-limiter in there when it hits a certain temp.
Smaller hills I've never had any trouble with. It's things like I-90 from Seattle to Snoqualmie(Climbing like 2500 ft in 19 miles) with a heavy trailer. That can get interesting.
Well, he either needs to spend a lot of money on a newer truck(which may or may not do this), or put some decent money into an IDI. The one thing I would be concerned about with someone like that is that while you can make an engine have plenty of power, you have to be careful with it or you might overheat it.
I've said it before and I'll say it again, while towing, don't go past 55. Go to YouTube and see for yourself what can happen. Especially with family in the trailer. No way.
