fuel problem
Old Aug 21, 2003 | 08:37 AM
dand427's Avatar
dand427
Question fuel problem
99 f350 i am driving down the road and the motor feels like it's running out of fuel. need to know were the fuel filter and pump is located and what to check and do. it has 120,000 miles on it just got it a month ago. help me help me thanks
Old Aug 21, 2003 | 09:20 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
fuel problem
The pump is on the driver side framerail about even with the front edge of the drivers door. The filter is smack dab in the middle of the engine under the plastic "powerstroke" cover
Old Aug 22, 2003 | 12:18 PM
etraveler13's Avatar
etraveler13
fuel problem
Regardless of the looks of a new truck (even one with 120k on it), Unless you know the person you bought it from, I recommend that you change the oil/water filter, located under the powerstroke cover in the middle of the engine. Change the oil, and filter, lube it, and check the tranny, and perhaps change the oil, and the same with the rear end. I prefe synthetics in the tranny and rear end, but thats is your call.
I just got a 2001 PSD with 77,000 miles on it, and felt much better knowing what was serviced, rather than guessing. Just my 2 cents...
Good luck...
KennethKvittum
6.4L Power Stroke Diesel
Dec 31, 2011 03:33 PM
jbeecham
Jul 2, 2010 07:34 AM
jmpopp
Feb 6, 2010 08:26 AM
pf350
Oct 18, 2007 11:00 AM
erndog
Sep 13, 2005 07:26 AM
