Up and Running, sort of...
Old Sep 12, 2016 | 04:41 PM
jvmcc's Avatar
jvmcc
I've taken my '53 F100 out a couple of times now. Just up and down the road, to shake some of the bugs out. It's been over twenty years since I've driven it. It's not as I remember it. The most noticeable thing about it is that it is all tightened up. It used to be that half the bolts were loose and it sounded like one big tambourine everytime I hit a bump. Now it's pretty quiet. A couple of things I noticed:
First, the ammeter needle swings all the way over to the charge side when the engine's running. It moves a bit back when I turn on the headlights. But, I do not recall that it ever read so high on the charge side before. Does it sound like I might have a bad regulator? Second, when I pop the hood after the engine has warmed up after a drive, thin wisps of smoke emerge from the filler/breather cap. I don't recall this condition ever existing before. Could this be leaky/loose valve guides? The "smoke" doesn't smell like coolant, so I don't think it's a head gasket leak. Any ideas? Anyway, here's a picture of how it is as on Sept 12 at 5:30 pm... Still have a few odds and ends to deal with before I go for a state vehicle inspection.
Old Sep 12, 2016 | 04:47 PM
schoo's Avatar
schoo
looks very nice to me
Old Sep 12, 2016 | 05:09 PM
raytasch's Avatar
raytasch
Believe Nothing
Great looking truck.
If the battery starts boiling, after a half hour hard run, you have a problem. What is your battery voltage, both static and with the engine at quarter throttle?
A wisp of smoke out the breather is not unusual for an old engine, especially one that has not been worked hard recently. If it emits heavy smoke from the road draft tube when in a hard climb, you should be at least slightly concern. Get it inspected and drive it.
Edit: Most likely not valves on a flathead.
Old Sep 12, 2016 | 08:28 PM
toby tough's Avatar
toby tough
I'm with Ray. Could be once you get some more miles on it things will clear up.
Old Sep 12, 2016 | 08:37 PM
38 coupe's Avatar
38 coupe
I wouldn't be concerned about the oil mist coming out the breather. I would be concerned about the charging system. Even with a dead battery you shouldn't peg the ammeter. If you are careful you can adjust the output current and voltage of a regulator. Most new regulators I have dealt with are way out of adjustment when purchased.
edit: Nice looking truck! Thanks for the picture.
Old Sep 12, 2016 | 09:02 PM
abe's Avatar
abe
Your truck looks great, John! Now I want to see more pics of your stock truck.
Ray, I think he has a 6 cylinder.
Old Sep 12, 2016 | 10:01 PM
Kurt G.'s Avatar
Kurt G.
John how did you do the amp meter, mine is after market and is similar to your description of operation.
Old Sep 13, 2016 | 06:39 AM
mike.rogers's Avatar
mike.rogers
great looking truck. Great color too. Hope you get the bugs worked out and back on the road.
mike
Old Sep 13, 2016 | 06:40 AM
rdemilt's Avatar
rdemilt
Wow - thats a beauty. Im sure you'll easily resolve the issue with the charging system. I wouldn't have too much concern with the smoke from the breather.
How about a few shots of the interior and the motor.
Old Sep 13, 2016 | 06:48 AM
jvmcc's Avatar
jvmcc
My is stock and, as far as I know, the gauge is original to the truck. So, I guess another possible diagnosis for the problem is that the gauge is out of whack. It's wired stock such that the main 10 ga.wire carrying all current comes right from the negative post of the battery (it's a six-volt positive ground system) via a terminal connection at the negative battery post on the solenoid, through the metal loop behind the "charging indicator" (the shop manual's name for the dash gauge), and then to the "B" terminal on the voltage regulator via a terminal connection at the the circuit breaker. I'm pretty sure that I got this right. Otherwise, I think, the needle would be pointing the other way. Like so many parts on this truck, the voltage regulator is old. I put it in new, but that was probably 30 years ago.....
Old Sep 13, 2016 | 07:10 AM
jvmcc's Avatar
jvmcc
Thanks for the kind words, Abe. My wife has taken several cell-phone movie clips of the engine starting for the first time and the truck's actual first voyage under its own power. But, she's got an Iphone and I have not figured out how to actually get those video files into my own own computer for editing. I suspect that the clips are in some sort of Apple proprietary format that I don't know how to modify. Anyway, I still have a few more days of going over it before I call it done. And even then, there is still work to do. I have to get the exhaust piping redone so I can hang a spare tire from the under chassis carrier. And, there is still orange peel and overspray to polish out on my paint job and touch up where I put the paint on too thin. When I do post more photos you will see that, while it pretty much uses components that would have been available in 1953, it's a mix of "Custom Cab" and standard. I installed the rear interior panels in behind the seat, interior door panels, turn signals, locking glove box, etc. But I don't have the teeth at the grille or the boomerang on the side of the hood. And I have seat belts, now.
Old Sep 14, 2016 | 09:38 AM
Kurt G.'s Avatar
Kurt G.
I am remiss, first I love your truck! I truly hope someday mine will be half as nice as that but that is wishfull thinking. I know it takes my battery a good 5 minutes for the gage to drop down to barely showing a charge, please more pictures you guys inspire me.
Old Sep 16, 2016 | 03:53 PM
petemcl's Avatar
petemcl
The breather cap smoke sounds normal.
As for importing from your wife's iPhone . . . She should have a little charging cube and if you unplug the cord from the cube there is a USB plug on the end of the cord. Just plug it in using the charging cord to the USB port on your computer. After a few seconds the iPhone should appear as a choice in Windows Explorer. Just move the files over to someplace you can find them on your computer. Easy as that.
Old Sep 16, 2016 | 04:04 PM
jvmcc's Avatar
jvmcc
I'll give it a shot.
Old Sep 16, 2016 | 04:15 PM
ghart's Avatar
ghart
Great looking truck, love it!
iPhones typically use the MOV format which is pretty specific to Apple devices. Not sure things are still the same, but you used to have to install QuickTime to be able to play MOV videos on a Windows machine. An easy option would be to just have her upload them to YouTube - it provides some basic editing options like trimming, if needed.
