1995 f250 7.3 power stroke
Old 09-12-2016, 08:10 AM
Silewski11's Avatar
Silewski11
Silewski11 is offline
I was looking at possibly buying a 95 power stroke. The guy says he replaced glow plugs and a brand new turbo. Still says it has running issues as well as a broken front axle shaft. Says it runs rough and has a low lcp code. Any insight on this would be greatly appreciated. Thanks
Old 09-12-2016, 09:37 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
injector orings might need replacing, IPR need rbuild or replace, IPC might be bad, HPOP could be worn, wrong engine oil might be used, air in system, starter not cranking fast enough
A ODBII scanner would be helpful but you need to get the right kind to narrow the issue and a 4000 PSI gauge could come in handy.
Axle shaft can be replaced but there could be other damage
Old 09-12-2016, 12:08 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
If he broke an axle, I feel like that truck was rode hard and put away wet.... She might be a bigger problem than she's worth
Old 09-13-2016, 10:07 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
ding ding ding!! Um, yeah, save yourself the trouble.
Old 09-13-2016, 11:34 AM
Silewski11's Avatar
Silewski11
Thanks guys! He was asking quite a bit for it as well. So you just made the decision way easier!
Old 09-13-2016, 12:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
Welcome to the forum and to reallity
PhotogSam
18
03-12-2014 12:58 PM
rusty-150
03-24-2011 07:56 AM
TopThis8899
11-10-2006 05:40 PM
TexasRoughneck
08-01-2005 06:13 PM
Quick Reply: 1995 f250 7.3 power stroke
