axle?
Old Nov 9, 2006 | 08:53 PM
TopThis8899's Avatar
TopThis8899
axle?
is there a way, or can any of you tell me what front axle i have in my truck. if there is a way for me to tell, let me know. i just got it and would like to know. its a 1995 F250 4x4, 7.3 powerstroke, the axle code is 39, if that helps. thanks
Old Nov 9, 2006 | 09:07 PM
theman79's Avatar
theman79
quick answer
just call the parts dept at your local ford house and they will tell u everything you need to know about it.
Old Nov 9, 2006 | 09:37 PM
jroehl's Avatar
jroehl
https://www.ford-trucks.com/article/...de_Chart_.html
Jason
Old Nov 10, 2006 | 09:05 AM
MustangGT221's Avatar
MustangGT221
Should be a D50 TTB since it has a diesel.
Old Nov 10, 2006 | 11:06 AM
DOUBLEF222's Avatar
DOUBLEF222
Alot Of Newer F250's Have Dana 50's In Them Unless They Are A Special Order Truck Then They Would Have A 60
Old Nov 10, 2006 | 11:08 AM
DOUBLEF222's Avatar
DOUBLEF222
And Alot Of Gas Powered Have 50's In Them
Old Nov 10, 2006 | 11:34 AM
bocephus_3349's Avatar
bocephus_3349
as stated above all 250 unitll late 97 used the ttb d50. and 350 was the solid 60. i could be wrong.
Old Nov 10, 2006 | 12:43 PM
MustangGT221
The F-250 had either a D44 HD or D50 TTB depending on certain things. My regular cab F-250 had a 8600gvwr but it had a d44 up front. My dad's truck was almost identical except it was a supercab and it had a D50 up front. I believe supercab/long beds and diesels/big blocks got the heavier front end....something like that.
This is the 87-96 forum (97 too for the heavier trucks)...the newer 98+ trucks are different.
Old Nov 10, 2006 | 05:40 PM
DOUBLEF222's Avatar
DOUBLEF222
My Buddy Had An 88 With A Small Block Reg Cab And It Had A D50
