Sponsored by: Real Truck
Rattle while towing
Old Sep 10, 2016 | 05:34 PM
Hoot_73's Avatar
Hoot_73
Rattle while towing
Hey everybody, i have a e99 F250, 4x4 short bed extended cab, V10, automatic, 189000 miles. While loaded it has a very loud rattle coming from behind the drivers seat, definitely sounds metallic and seems to get worse over bumps while the rattle is present, it only starts at 70ish mph. I have done, ball joints, tie rod ends, sway bar bushings and end links, had the rear driveshaft checked and balanced and removed the front driveshaft all without helping the rattle. It also has a very pronounced snapping sound when going from park to drive or drive to reverse and vise versa. At this point i am leaning towards either transmission or transfer case, but i wanted to check here to see if i was missing anything first. Thanks in advance!
Old Sep 10, 2016 | 07:30 PM
ugh3012's Avatar
ugh3012
If this only happens when you are towing, I would check the hitch and the frame area where the hitch is attached.
Old Sep 10, 2016 | 09:57 PM
Hoot_73's Avatar
Hoot_73
I should have specified, its loaded whether towing or just a load in the bed.
Old Sep 10, 2016 | 10:15 PM
twigsV10's Avatar
twigsV10
Is the front of the box contacting the cab by any chance?
Old Sep 11, 2016 | 09:08 AM
Hoot_73's Avatar
Hoot_73
Checked this morning, no contact between cab and bed.
Old Sep 11, 2016 | 10:44 PM
twigsV10's Avatar
twigsV10
Give your rear springs a good look also, are there any broken leaf springs or missing overload spring bushings (on the frame contact points) that can make metal to metal contact with a load on the back of the truck?
friscocrownie
Jan 10, 2018 09:52 PM
tonebone
All Things Towing
Jan 28, 2016 08:48 AM
Redneck1465
22
Feb 27, 2008 07:46 PM
f250meangreen
Apr 12, 2005 05:06 PM
TonyG
All Things Towing
Nov 12, 2001 11:29 AM
