Posi vs 4X4
Old Oct 21, 2001 | 08:55 PM
TonyG's Avatar
TonyG
Posi vs 4X4
I know this is the towing board, but this question does relate to towing. I presently have a '87 CC 4X4 w/460 5 speed, 3.55 gears, single axle. I tow reciver hitch trailers up to about 7000 lbs. I sometimes also have a ton or a little more in the bed. I don't have a gooseneck hitch as of yet. I am considering buying a good used '87 CC with a 4.11 posi dually to do my towing with and use the truck I have now for a carpentry truck and light towing. I'm concerned that I'll miss the times when the 4X4 comes in handy, like when a couple inches are on the ground and the snowplow hasn't gone yet. I also like the low range of the transfer case for backing around and the 4 wheel drive for times in slippery surfaces or on hills. I'm wondering what other pullers and towers think of 4X4 vs posi in terms of traction and getting stuck or 'unstuck'.
thanks,
Tony
Old Oct 22, 2001 | 11:02 AM
jim henderson's Avatar
jim henderson
Posi vs 4X4
The dually setup may make the difference, but I have no experience there.
I have a 94 F250 4x4 with limited slip/posi, not a dually. 99% of the time 2x4 does fine, but on those rare occasions, usually a couple times a year, having the 4x4 and low really gets my butt out of a sling. Especially helpful when towing a load and getting stuck.
BTW sounds like the load you are putting on the rear may be a bit much. Check your GAWR ratings and if you get a chance, put your truck on a scale. A ton in the bed plus a trailer is probably too much for safety and wear and tear.
Good Luck,
Jim Henderson
Old Oct 29, 2001 | 11:54 AM
TonyG's Avatar
TonyG
Posi vs 4X4
Good Luck,
Jim Henderson
Jim, Thanks for the input. The truck weighs about 6000 with fluids full. It will liscense at 10,400 I think, but I have it dropped to 9000 for a registration fee break. The ton in the bed allows for either another 1000# in the cab or on the hitch. I have a 10,000# rating on the reciver hitch and ball so I can load 1/10 of that on the tounge. 7000 lb trailers are made for 700 lbs on the tounge, so I try to keep it around there. I am probably overloaded on my registration at times, depending on how many people are in the cab, but I think I have a way to go before overloading the truck's limit. I try to stay away from towing 10,000 lb trailers though with the 3.55 rear.
Tony
Old Oct 30, 2001 | 12:40 PM
webguyrich's Avatar
webguyrich
Posi vs 4X4
Tony,
Be aware that your licensed weight only satisfies the DOT, Highway Patrol doesn't care about your license, they care about the manufacturer's ratings. If you're over weight, some states make you park it until you can get someone out there who can legally tow it for you. Just some food for thought
-Rich
Old Nov 6, 2001 | 10:13 PM
Ultramagdan's Avatar
Ultramagdan
Posi vs 4X4
Posi on a duelly? I love posi but it can be abused. Even on a normal axle it takes a tough rear end to handle the cornering in normal driving. On a duelly it must be even worse. The clutches in the axle would get a good workout. A 4x4 duelly I think is the way to go. I know of a few guys that thought that posi was the solution for towing on a 2wd truck. A 3/4 with a heavy front end (diesel) and a 2WD posi. They bought a 3/4 4X4 duelly in less then 6 months.
98 F250LD 4X4
Old Nov 12, 2001 | 11:29 AM
RJKobbeman's Avatar
RJKobbeman
Posi vs 4X4
87thhunter
50
Mar 1, 2016 11:56 AM
charlierogers
Sep 30, 2008 08:31 PM
cougar190
19
Jun 18, 2008 08:42 PM
Tony1790
Mar 20, 2006 01:53 PM
masterbeavis
Nov 1, 2001 08:35 PM
