Fuel level float repair
Old Sep 10, 2016 | 02:58 PM
john jamieson's Avatar
john jamieson
The brass float on my fuel level sending unit has a hole in it. Anyone repaired these floats or just order a new one?
Thanks
Old Sep 10, 2016 | 03:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks
Carpenter sells a replacement float for around 5 bucks.
C0AZ-9202-B = The original float is still available from Ford, it's the same 1957/79 for all FoMoCo vehicles.
Old Sep 11, 2016 | 04:50 AM
Crop Duster's Avatar
Crop Duster
For 5 bucks this probably isn't worth the effort but this is how we did it on carburetor floats. First heat a pan of water to just below boiling. Submerge the float and look for bubbles to mark where the leak is. Drill a 1/16 hole in each end of the float. Gently blow all the fuel out that has leaked inside the thing. Clean it up really good. Re-solder the seam first then both of the holes. Use a good electric soldering iron. NO TORCH! Unless you want to set off a little bomb on your work bench. Don't let it cool while you solder it or the air expansion in it will blow a pinhole in the solder when you close the last hole. After it has cooled repeat the hot water dip to leak check it.
Old Sep 11, 2016 | 09:10 AM
john jamieson
Thanks for the tip on the soldering iron. I may try that before ordering a new one.
Old Sep 11, 2016 | 09:11 AM
BarnieTrk's Avatar
BarnieTrk
I put this one in my '65 F250 tank: https://www.summitracing.com/parts/omx-1772901 for: $3.97
Summit doesn't list for a Ford but it looked the same & fit into the hook arm the same way - only difference being it is made of plastic. I think it will last longer than the OEM brass unit if you use ethanol blended fuels.
BarnieTrk
Old Sep 11, 2016 | 02:42 PM
Merlyn James's Avatar
Merlyn James
I ordered a whole unit gasket and all from dennis carpenter. I was rinsing out the tank and the metal parts of the sending unit arm were too rusted to put back in the tank with a clear conscience..
Cory74700
16
Sep 18, 2013 09:56 PM
dieselsubmariner
21
Nov 23, 2012 05:43 PM
E-Mo
Dec 31, 2011 08:10 AM
JasWood
Aug 17, 2010 09:12 PM
4tl8ford
Jan 5, 2007 07:04 AM
