press sizes
Old Sep 10, 2016 | 09:09 AM
greentruck72's Avatar
greentruck72
press sizes
if i'm gonna be pressing on axle bearings on axle shafts, what size press would be the minimum?
Old Sep 10, 2016 | 09:45 AM
DeepRoots's Avatar
DeepRoots
I got tired of paying the local guys $30 everytime I wanted a bearing pressed on.
I bought the cheap 12ton from Summit for $150. (it woulda cost me twice as much to build one)
Figured if I used the dang thing a few times it'd pay for itself.
Now don't get me wrong, it's a rickity piece o junk, BUT......
It works.
I've pressed on/off all Ford 9inch third member bearings without issue, pinion bearings etc etc.
I also pressed on Ford 9 inch axle bearings without issue, tho you do need to get creative due to the length of the axle.
I think if I was using the thing everyday I'd go ahead and spend $600+ on a press that was easier to use, but for the occasional mechanic it works fine: https://www.summitracing.com/parts/sum-917030/overview/
Good luck
Drew
Old Sep 10, 2016 | 10:08 AM
greentruck72
thats what i was hoping to hear.
Old Sep 10, 2016 | 10:37 AM
DB429SCJ's Avatar
DB429SCJ
Harbor freight has a 20 ton for $199.
Old Sep 10, 2016 | 03:04 PM
78 PEB's Avatar
78 PEB
Ive got a HF 20 ton........paid $159 for it and for the price.......it isn't bad!
Old Sep 10, 2016 | 08:20 PM
Blue and White's Avatar
Blue and White
I got a HF 20 ton. While less "should" work most of the time, it is nice to have the extra. I have needed it a few times... as in put the handle extension on the press jack and crank hard.
Old Sep 10, 2016 | 09:09 PM
DeepRoots's Avatar
DeepRoots
On another note.....
Spend the money you save on bearing/bushing tools:
OEM Bearing race and seal driver set 27119- Read2Reviews onOEM #27119
They are super handy. I also made up a tool box of odds and ends that make pressing bearings on easier (stuff like old bearing inner races, pieces of perfectly square pipe, etc).
rhw
Feb 8, 2019 01:15 AM
rpatrick
Aug 15, 2009 07:23 PM
tbm3fan
Sep 24, 2007 01:58 PM
1982fordf100
May 28, 2005 01:49 PM
brown 4x4
Sep 26, 2003 12:53 PM
