Rear Axle Bearings - Replace or Not?
OK - after getting the axles and seals removed (previous thread) I am wondering if I should go ahead and replace the axle bearings.
For kicks, I slid the axles back in and checked the play and BOTH sides have a slight amount of play in the axle. Normally I would think this would indicate new bearing time but I am not familiar with this type of bearing.
What do you all think - at 165k miles should I go ahead and replace the rear axle bearing while I have it apart or is this slight play normal and these bearings last forever?
Rob
Rob
Given the pain in the tail I've alread experienced, combined with the gear oil mess, I am going to go ahead and replace them. I HATE to do half the job now and the other half (plus the first half again) in a month.
Thanks for the confimration.
