HEI dizzy upgrade
Old Sep 9, 2016 | 04:06 PM
jordandkaspar's Avatar
jordandkaspar
HEI dizzy upgrade
So I have a 1996 F150 that lost spark. There is no signal from the PIP sensor. I was thinking about using an HEI distributor to cut out alot of wiring. My question is will the new dizzy not having a PIP sensor cause problems in the ecm/ecu?
Old Sep 9, 2016 | 04:23 PM
rla2005's Avatar
rla2005
The PCM relies on the PIP signal to trigger spark and turn the injectors On/Off. No PIP..no spark or fuel. Also keep in mind on 1994 and later trucks the computer controls the dwell (spark on time) as well.
Old Sep 9, 2016 | 09:38 PM
tempest411's Avatar
tempest411
The stock system doesn't have that much wiring, and actually works pretty good. In fact, putting in a distributor that has the module on the distributor itself would be a step backwards.
NavySeal44
Nov 7, 2018 01:22 PM
Drock117
Nov 15, 2017 07:23 PM
red5standingby
Dec 23, 2016 02:55 PM
jgreen82
Dec 8, 2013 04:31 PM
mox-ct
37
Aug 17, 2010 04:15 PM
