3" Ball Mounts
Old Sep 9, 2016 | 09:50 PM
gbkeith's Avatar
gbkeith
Originally Posted by Kenv
No...it WILL rattle around...but Ford has already put out the fix. Go to the center stack, turn the volume **** slowly to the right, and crank that new song "I've got a brand new Superduty and I'm so happy now!!" When that song ends, just flip channels until you find the next adapter blocker hit.....LOL. Seriously though...I checked on the B&W site to see if they are working on a new 3" shaft for the Two & Stow combo hitches. I don't really want to run my current 2" in the middle of TWO spacers. I'll have to give them a call and see what's on the drawing board for these Super squares we will have on the back of our trucks.
Back in August B&W told me a 3" Tow and Stow was something they were looking in to but didn't have a timetable.
Old Sep 9, 2016 | 09:58 PM
K A M's Avatar
K A M
Originally Posted by tima597
Any thoughts on what will be the best amount of drop to go with in the 17s assuming everything is left stock on the truck?
2 inch ball, Height to top of ball 18 inches from ground loaded.
2 5/16 inch ball, Height to top of ball 20 inch from ground loaded.
Old Sep 10, 2016 | 08:43 AM
Rasty1's Avatar
Rasty1
Now dat dare is funny
Old Sep 10, 2016 | 08:50 AM
17 Oaks's Avatar
17 Oaks
So let me get this straight. The Ford SD has an OEM 3" hitch and in order to use it I need a 2 ½ adapter and inside of that I need a 2" adapter and I need these because there is no 3" currently available?
If I am wrong please correct...
Old Sep 10, 2016 | 08:56 AM
Rasty1's Avatar
Rasty1
Thats correct and only when you add the heavy towing package you get the 3" with two adapters stuffed in the receiver hitch.
Standard it will come with a 2 1/2" receiver hitch and the adapter for 2".
Old Sep 10, 2016 | 09:08 AM
17 Oaks's Avatar
17 Oaks
Thank you...and if you are driving a SuperDuty then this is a must have!!
So when someone asks what do you use for an adapter, I will just tell them if its a light pull I use the hitch off a Dodge Ram, if its really light, and I need a 2 " adapter I just use a Chevy...works for me.
Old Sep 10, 2016 | 09:39 AM
Rasalas's Avatar
Rasalas
Correct, partially. There are 3" ball mounts available and more on the way. I currently use a 2 1/2" and have several ball mounts in that size so I only need one adapter for the 3". After towing with the 2 1/2" the 2" look really wimpy. I will probably go with a 3" which has easily changed heights since I am tired of having to select a different mount for each trailer. I am interested in the Gen-Y hitch which will handle anything I will ever tow on a tag along. If they do not produce a 3 inch I will permanently attach a sleeve on a 2 1/2" but I imagine they will produce one. But then again I like the reduced weight of the Weigh Safe which will have their 3" on the market just in time for SEMA in November.
Old Sep 10, 2016 | 09:42 AM
Rasalas's Avatar
Rasalas
Ha Ha. But I don't understand how does the Fiat Laramie fit in?
Old Sep 10, 2016 | 09:43 AM
Rasalas's Avatar
Rasalas
The heavy duty tow is only for the F250. All other SuperDuties come with the 3"
Old Sep 10, 2016 | 09:46 AM
System's Avatar
System
Prolocutor
I'm going to order a Weigh Safe 3" when they are available and get rid of the plethora of 2" ball mounts I have in all different size drops. They should go on CL without a problem.
Old Sep 10, 2016 | 10:14 AM
Rasty1's Avatar
Rasty1
Mine is not coming with a 3", don't tow enough to warrant going 3" but have order the weight safe 2 1/2", great hitch.
Old Sep 10, 2016 | 10:16 AM
Rasalas's Avatar
Rasalas
We should get together and have a mega sale. I built a rack which holds 8 ball mounts neatly against the wall. Right there for the selection. Different drops, ball sizes, pintle, tube size etc. It now has all 8 slots full plus 2 laying crosswise and a 30" extension resting against it as well. And the bike rack too which usually tips over at the least convenient times. I am still a little afraid of the aluminum but then again I don't haul equipment much anymore and since it is always on a borrowed trailer I will use another friends gooseneck.
I am intrigued by the weigh safe but I occasionally pull a pintle hook trailer. That is what caught my eye with the Gen-Y mount. Then again, I guess having a couple of mounts on the rack wouldn't be too bad.
Old Sep 10, 2016 | 10:17 AM
  #28
Rasty1's Avatar
Rasty1
Who ever dies with the most mounts ---- wins!
Old Sep 10, 2016 | 10:36 AM
  #29
Bat4x4's Avatar
Bat4x4
Me too
I'm going to order one also but I am also waiting for them to make a dust cover for the keyed lock. Since I can see that it will be a problem up here with the salt and sand they use on the roads in the winter.
Old Sep 10, 2016 | 10:39 AM
  #30
System's Avatar
System
Prolocutor
I never leave mine when not towing so I'm not too worried about it. But yes, that is a good idea...
