A putter
Old Sep 8, 2016 | 09:01 PM
Kdoggkvn's Avatar
Kdoggkvn
A putter
So I've noticed that when I fire up my truck for the first 10 seconds or so if I have my foot on the throttle it will putter as if its cold just needing to warm up I let my foot off the throttle white smoke comes out during the day if I were to be putting it in neutral and put my foot on the throttle raising the RPM's up high I would also get this putter as if something is slowing down the rate of fuel at higher RPMs I have already replace my water fuel separator filter and was thinking maybe it could be injectors but also thought about swapping the injection pump just so that everything was brand new any advice to help steer me in the right direction would be great thanks guys
Old Sep 8, 2016 | 09:28 PM
Jaime74656's Avatar
Jaime74656
Time to brake out the fuel pressure gauges, you IIRC should see around 60psi
Old Sep 8, 2016 | 09:33 PM
Kdoggkvn's Avatar
Kdoggkvn
Im not to familiar with the term IIRC?
Old Sep 8, 2016 | 10:05 PM
Rikster-7700's Avatar
Rikster-7700
IF I Remember Correctly. You could indeed have a fuel delivery problem (And yes 60 PSI is right around where you should be on a stock fuel setup).A gauge will let you know real quick, and can be a relatively easy and cheap diagnostic tool. These trucks have a known flaw with the pick up foot and screens located in the tank. Search the forum for hutch and harpoon mod, these will give you some idea of the issue and its fix.
This in not to say that this will be your problem, but an excellent and worthwhile starting point.
Old Sep 8, 2016 | 10:07 PM
Kdoggkvn's Avatar
Kdoggkvn
Thanks.
I'm sure of a problem. Tomorrow morning ill make a video and upload to youtube .
Originally Posted by Rikster-7700
IF I Remember Correctly. You could indeed have a fuel delivery problem. A gauge will let you know real quick, and can be a relatively easy and cheap diagnostic tool. These trucks have a known flaw with the pick up foot and screens located in the tank. Search the forum for hutch and harpoon mod, these will give you some idea of the issue and its fix.
Old Sep 8, 2016 | 10:23 PM
timmyboy76's Avatar
timmyboy76
Check out HUTCH mod
Old Sep 9, 2016 | 01:19 PM
hydro man 17's Avatar
hydro man 17
Just an FYI, there is no (fuel) "injection pump" on these engines. They run on high pressure oil for injection pressure. Nominal fuel pressure is ~ 60 PSI.
Old Sep 9, 2016 | 01:21 PM
Kdoggkvn's Avatar
Kdoggkvn
Youtube video coming . Uploading ..........
Old Sep 9, 2016 | 10:49 PM
Kdoggkvn's Avatar
Kdoggkvn
Https://youtu.be/VvJJ8uwEWTQ
77_F150_4x4
Jun 12, 2014 03:20 PM
superduty4x4
28
Jan 13, 2011 05:53 PM
Fordbronco69
19
Dec 18, 2010 09:46 PM
86stepsideF150
23
Sep 23, 2007 12:44 PM
sailors30
Aug 28, 2006 05:24 PM
